2005 Chrysler Town & Country 3.8 P0406 EGR sensor high
  • Mechanic 350
  • Mechanic 350's Avatar Topic Author
8 years 5 months ago #20672 by Mechanic 350
trying to determine if this electronic sensor is defective. checked all power and grounds, pins 2,3,4, and they all looked good. Have 4.97v reference. that looks good. but when I tried to use the meter as paul taught me, using it as a jumper wire with a screen, I cannot get the egr valve to click. the settings for the meter was red lead to amps and black grounded to -battery terminal. when I did this test, nothing happened. Can anyone assist in determining what procedures I failed to do? thanks everyone.
pin out is as follows:
1- egr solenoid signal = 3.51 that's the reading I'm receiving. I'm not sure if this wire is suppose to give me 12 volts. dark blue -light green
2- 5V supply= that's good. pink-yellow
3- sensor ground= that's good - dark blue/dark green
4- ground= that's good. - black/dark blue
5- empty
6- egr solenoid control - dark blue/violet.
thanks again.
  • cheryl hartkorn
  • cheryl hartkorn's Avatar
8 years 5 months ago #20674 by cheryl hartkorn
Replied by cheryl hartkorn on topic 2005 Chrysler Town & Country 3.8 P0406 EGR sensor high
do you have a bi directional scanner? if not you could remove the sensor backprobe the signal wire and move the pintle with a screwdriver and look for a change... if it doent change replace it
  • Mechanic 350
8 years 5 months ago #20677 by Mechanic 350
Yes I have a bi-directional scanner. It’s kind a old but I have the Modis 7.2
  • Mechanic 350
8 years 5 months ago #20678 by Mechanic 350
The egr on this minivan is a pain in the rear. To remove. Any other test you suggest to do?
  • cheryl hartkorn
8 years 5 months ago #20679 by cheryl hartkorn
do you have the ability to control it? if so thats what id do while checking the signal to change.
  • Mechanic 350
8 years 5 months ago #20680 by Mechanic 350
Believe it or not I do not have the capability to control the EGR to open it or to close it for some reason my Motdis doesn’t provide that feature I could only go and do DC and resistance tests only What I do not understand is when I jumped the EGR with my multimeter like Paul did in a video I did not get any 12 V reading Thanks for your help
  • Dave101
  • Dave101's Avatar
  • Show me what it's not!!
8 years 5 months ago #20746 by Dave101
Back probe Terminal 4 EGR control. Should read .5 volts at idle. Juice engine to about 2000 rpm. You should read about 12vdc
  • Mechanic 350
8 years 5 months ago #20747 by Mechanic 350
my pin out taken out of my modis told me that pin out for erg solenoid control is #6 dark blue/violet
#4 is my regular ground, black/dark blue
once I juice engine to 2000 rpm, if I don't see 12vdc, then I can condemn the erg?
thanks for the response. I'll let you know of my findings.
  • Dave101
  • Dave101's Avatar
8 years 5 months ago #20750 by Dave101
I'm looking in Mitchell and it's telling me Pin 4 however the colors are correct. Dark Blue/Violet. I would do a resistance test on the solenoid before I would pull the trigger and call it bad. Pull the connector off and measure between the solenoid. Pin 4 & 6. You should read about 25 - 45 ohms according to Mitchell.
