2005 Jeep Liberty runs 4 seconds and stall
  • Rabbit
  • Rabbit's Avatar Topic Author
8 years 5 months ago #20460 by Rabbit
2005 Jeep Liberty runs for 4 seconds and stalls..
It had a viper alarm system
It has injector pulse
It has spark
The key it come looks like after market key
It has No Sentry Module on the ingnition cilinder
The car was not used for 2 years
Any help
thank u
8 years 5 months ago #20466 by Dreamcatcher300
Replied by Dreamcatcher300 on topic 2005 Jeep Liberty runs 4 seconds and stall
Hello
I take it you have no codes?
This is difficult as it could be many things.
Have you ruled out fuel delivery, MAF sensor testing and crank&cam sensor?
I've seen a bad fuel pressure regulator case this symptom before now
Mick
8 years 5 months ago #20469 by Tyler
Replied by Tyler on topic 2005 Jeep Liberty runs 4 seconds and stall
Like Dreamcatcher300, I'm thinking of a fuel delivery issue. Pumps are a common failure on those. Can you monitor pressure during the start/stall?
Or, get some alternate fuel (carb cleaner, propane, whatever) and feed it into the intake through the brake booster hose. Watch for injector pulse at the same time. If you can keep it running by feeding it fuel, AND the injector pulse doesn't disappear, then definitely look at a fuel delivery issue.
You might also consider that the fuel in the tank may be bad after sitting so long.
