2010 Ford F150 4.6 3v 4x4 Trim slowly rises and will set open loop fault.
- wtrapp1979
- Thank you received: 3
8 years 5 months ago #20261
by wtrapp1979
2010 Ford F150 4.6 3v 4x4 Trim slowly rises and will set open loop fault. was created by wtrapp1979
Hey Everyone,
I believe I have a pretty good one for you. 2010 Ford F150 4.6 3v (non-flex fuel) 4x4. Vehicle will set a p0171 and p0174. The Customer concern is that occasionally the vehicle will stall coming to a stop. I did not experience the stall coming to a stop or driving. The only code in the PCM was evap leak small in history. When I drove the vehicle to verify concern, I found no run-ability problems. Plenty of power and no stalling under normal driving. Brought it back to my shop and let it idle outside a bit. After 10 mins or so I heard a significant stumble. I hooked the scanner up and no codes at this point.I pulled data up on the Verus and short and long term trim for both banks were 0 and the fuel system status read (open loop fault) but still no codes.
I cleared the KAM and went back into data. The short term fuel trim slowly increased to 50 over a few minutes, then fuel system status went to open loop fault, trims dropped to 0 and the truck just about stalled. This will happen constantly over and over. I monitored fuel trim at 1500 and 2500 and total trim is about 20-30. Fuel pressure was 60psi. However, I wasn't happy with the volume the pump produced. Scope pattern on fuel pump module shows a nice square wave with 14 available and 14 used that runs at 60% duty cycle at idle, which is what the PCM is commanding. I pulled a current ramp and it had one commutator that looked shorted. Pump RPM was about 3400, which seamed low. I replaced the fuel pump and now have 65 psi. Trims are still the same. MAF has been changed out with reman cardone. Scan data shows about 3v from MAF with a wide open snap and .7 at idle. When I use the component test scop I can not get a pattern. I am not familiar with the sensor type. The Verus says it is a DC voltage sensor. maf.PNG Unpluged I have a 5v ref for the IAT and signal return.The MAF I have 2 pins that read 2v available voltage, a ground, and a 12v with the connector unplugged. This seems odd to me. Plugged in both 2v wires drop to 0. I shrugged it off at first since I had good voltages in the PCM, however I am thinking it may be a substituted value.
The truck also does have a small exhaust leak from a broken stud at the passenger side manifold so I cant rule that out, but I would think that would affect one bank only. I did smoke the intake and intake tube upto MAF and no leaks. I also capped off the brake booster, 4x4 actuators, and evap purge lines. Still same trim problem. Any suggestions?
- cheryl hartkorn
- Thank you received: 130
8 years 5 months ago #20263
by cheryl hartkorn
Replied by cheryl hartkorn on topic 2010 Ford F150 4.6 3v 4x4 Trim slowly rises and will set open loop fault.
maybe try checking fuel quality? 50% positive is very lean. dirty injectors?
- wtrapp1979
8 years 5 months ago #20272
by wtrapp1979
Replied by wtrapp1979 on topic 2010 Ford F150 4.6 3v 4x4 Trim slowly rises and will set open loop fault.
I did check fuel for alcohol. It was 10%. When I did the pump I drained fuel and put good fuel in it. No change. I ran some sea foam through injectors as well.
