2000 Honda civic LX, crank, no start.
- Bonehead
8 years 5 months ago - 8 years 5 months ago #20244
by Bonehead
2000 Honda civic LX, crank, no start. was created by Bonehead
2000 Honda civic LX D16YZ engine, 4 speed auto, crank no start, no injection pulse, no spark. DTC's are unknown because I do not own a scanner.
No control on coil (-), test light stays lit, coil is not shorted or open because I was able to bypass the ICM and make the coil spark.
Here's what I've gathered so far, everything AFTER the ignition coil is good, however the control side is suspect.
The issue lies within the connector that goes into the distributor. On the bottom row of pins, these pins are on the ground side of the circuit yet the last pin on the far right has power. This is a short to ground on the wire or worse case scenario a shorted driver correct?
Also, top pins all have faint ground signals, except for the top right pin, it's completely dead, that top right pin is my CKP sensor if I'm correct.
Here's a video if it helps. Sorry about it being inverted. Also bear with me, this is my very first time diagnosing a car.
Last edit: 8 years 5 months ago by Bonehead. Reason: Forgot video link
- Ben
- Thank you received: 215
8 years 5 months ago #20258
by Ben
Replied by Ben on topic Re:2000 Honda civic LX, crank, no start.
Pulling codes would probably help with a direction to go, I don't work on this style Honda ignition often so I can't say if what your seeing on your distributor connector is correct, someone else may have more insight to that. but I would recommend a cheap obd2 code reader for a diagnostic direction . Does it have injection pulse?
- Bonehead
8 years 5 months ago #20273
by Bonehead
Replied by Bonehead on topic Re:2000 Honda civic LX, crank, no start.
It doesn't have injection pulse, I would get a cheap code reader but don't think I can buy one yet.
Also check engine light doesn't come on either.
- Ben
8 years 5 months ago #20279
by Ben
Ok it could be that the bulb has been removed or the pcm is not powered up or is shorted either way we will want to check for a 5v reference at a sensor (which 1 won't matter so much) a diagram would help in identifying which sensors have 5v to them but typically your cam and crank sensors your map and maf sensors your tps sensor and several others will have a 5v ref a ground and a signal wire check any one of them for 5v if there is no 5v ref check for power and ground to pcm I'll pull a diagram and direct you further if that's where this leads but start with 5v check
8 years 5 months ago #20286
Replied by Tyler on topic Re:2000 Honda civic LX, crank, no start.
Definitely agree with the 5V reference check. Very quick test to see if the PCM is working, CEL or not.
I can tell you that most of those pins don't react because they're sensor inputs out of the distributor. There's three separate VR-type sensors in the distributor, two wires each, for six total. The one wire that lights is probably the coil/ICM power feed. Download and open the diagram below. It's an excellent represenation of this system.
While you're doing voltage checks, do the injectors have power during cranking? I ask because the injectors and the PCM share the same power feed.
- Bonehead
8 years 5 months ago #20301
by Bonehead
The injectors do have power, and I could bypass them to spray too. I'll look at the diagram, thanks for giving it to me.
- Bonehead
8 years 5 months ago #20499
by Bonehead
Update.
Key OFF (Literally in my hands at this point) PCM driver appears to be shorted, with test light connected to power, the control wire STAYS lit/on
Disconnected PCM
Test light goes out
What do you guys think?
Disconnected PCM
Test light goes out
- Bonehead
8 years 5 months ago #20552
by Bonehead
I really need you guys help on this one please.
- Ben
8 years 5 months ago #20554
by Ben
Did you check 5v reference?
- Bonehead
8 years 5 months ago #20558
by Bonehead
Does the engine have to be cranking to check 5v references?
I had KOEO and checked at the intake air temperature sensor and it was low voltage.
I tried to t-pin the other sensors but the rubber was too tough. I may need a piercing probe.
Here's a component diagram I used.
- Bonehead
8 years 4 months ago - 8 years 4 months ago #21016
by Bonehead
Lots of progress so far.
Tested for 5v references and they are not present.
I got .030 - .170 volts.
TPS sensor is unresponsive, the readings stayed static even when at WOT.
G101 computer ground is good.
No short to ground on sensor wires.
No open on sensor wires.
Sensors wires have a good ground.
I have to say it must be the ECM. Circuit integrity is good all around
Last edit: 8 years 4 months ago by Bonehead.
- Thank you received: 1139
8 years 4 months ago #21067
Replied by Noah on topic Re:2000 Honda civic LX, crank, no start.
Are you saying that the yellow and green wire from the PCM to the distributer is always grounded? Including with the key on or off and also while cranking?
If I'm on the same page you are, it sounds like a killed PCM when you add the lack of a CEL and no 5v ref.
Also, not not picking, but to check the 5v reference on a thermistor, (i think you said you checked the intake air temp sensor?), the sensor must be disconnected.
I like to check the tps right there on the throttle body. With the key on, you can unplug it and just check all 3 pins with a volt meter.
Technically, you'd want to back probe the connector in case that sensor happened to be pulling the 5v ref to ground. You'd miss it by disconnecting it, but I don't think that's going to be super critical.
