Crank sensor resistance?
- timothy.spencer
- Thank you received: 2
1 year 8 months ago #81100
by timothy.spencer
Crank sensor resistance? was created by timothy.spencer
Anyone who has a subscription to Identifix or All Data have time to look up the resistance spec of the crankshaft position sensor on a 2007 Camry 2.4L? I have Mitchell and just want to verify what other sources say it is, to make sure it's not a misprint.
Thanks
Thanks
- ferris48
- Thank you received: 47
1 year 8 months ago #81101
by ferris48
Replied by ferris48 on topic Crank sensor resistance?
1,150 to 1,450 ohms
- timothy.spencer
1 year 8 months ago #81105
by timothy.spencer
Replied by timothy.spencer on topic Crank sensor resistance?
Thanks. What source was that from? That's very interesting. Here's what Mitchell shows. I wonder why different sources show different values? I would have thought there would be 1 spec from Toyota, no matter what service data source we use.
- ferris48
1 year 8 months ago #81108
by ferris48
If I dig into OEM DIRECT I found what you found on Mitchell:
I'm using Identifix and searched for p0335 typical crank sensor code.Thanks. What source was that from? That's very interesting. Here's what Mitchell shows. I wonder why different sources show different values? I would have thought there would be 1 spec from Toyota, no matter what service data source we use.
- ferris48
1 year 8 months ago #81109
by ferris48
Check out this PDF
pdfhost.io/v/NHtE7oZjO_2AZFE_Engine_Control_System
Type in the page number in the upper left to jump to them.
Page 377 shows the Mitchell specs and the one from OEM DIRECT on Identifix
Page 185 shows a different resistance spec when you search for P0335
Hmmm, interesting...
- timothy.spencer
1 year 8 months ago #81646
by timothy.spencer
That is strange. Wonder why the specs listed for this car aren't all the same. What got me on to this topic was, I noticed the crank sensor in my wifes car was slightly out of spec. Bought a brand new one and it too was out of spec. Compared it to another car I have with a similar engine and it too was out of spec. Made me start wondering if the spec listed was wrong.
