Stft reading all over the place
- Fox.b
- Thank you received: 3
8 years 5 months ago #20172
by Fox.b
Stft reading all over the place was created by Fox.b
Uk. Renault Scenic 1.6 petrol 4cyl 2002. No DTC's No misfire.
Girlfriends car and she is thinking it's slightly heavier on petrol than it used to be. Used Snap-on to check fuel trims to see if it was adding fuel. No trims PID to check under manufacturer so I checked under EOBD. Car warm. O2 closed. Stft % is reading all over the place. Pos 10 then pos 3 then neg 16 then pos 23 then neg 6. No rhyme or rhythm. Always changing very quickly. Like different reading every 1/3 of a second.
My question is: has anyone ever seen the stft change this fast?
- Ben
- Thank you received: 215
8 years 5 months ago #20175
by Ben
Replied by Ben on topic Re:Stft reading all over the place
Nope
- KennedyAutoSolutions
8 years 5 months ago #20180
by KennedyAutoSolutions
Replied by KennedyAutoSolutions on topic Stft reading all over the place
Yes I have, first, make sure the car is in closed loop.
What are long term trims and idle and short term and idle.
What are they when driving?
If short term is going nuts while driving, check fuel supply like driving under load, also, Ive seen dirty / clogged injectors cause this issue as well.
- Toddthompson1970@yahoo.com
8 years 5 months ago #20181
by Toddthompson1970@yahoo.com
Replied by Toddthompson1970@yahoo.com on topic Stft reading all over the place
I will do some homework on this an let ya know if come up with anything be sure to let us know what the fix was when you get to the bottom of this thanks.
try to let you know something ASAP
- Fox.b
8 years 5 months ago #20187
by Fox.b
Replied by Fox.b on topic Stft reading all over the place
Haven't road tested.
Funny enough, it's not misfiring but the idle is slightly "wobbly". Sadly, I don't have a scope to check injector waveform.
