2001 Nissan maxima crank ref sensor corrosion on tip with rich condition
- Rusty
- Thank you received: 2
8 years 5 months ago #20643
by Rusty
Replied by Rusty on topic Re:2001 Nissan maxima crank ref sensor corrosion on tip with rich condition
Hi Ben, I cleaned the Maf and ran a scope on the and the response was smooth from 1.2 V at idle to 4.1 volts on wide open throttle. I checked on the scan tool only at idle earlier and that was 4.3 g/s and when I rev from idle which is 675rpm to 4500 rpm it ranges from 2.2g/s to 16.9g/s. and shows a smooth graph. I have a Delphi scan tool 150ds. Can you work with this data or do you need more. By the way I scoped my upstream o2 sensors and they are switching 3 times in 10 secs.
- Ben
- Thank you received: 215
8 years 5 months ago #20646
by Ben
Replied by Ben on topic Re:2001 Nissan maxima crank ref sensor corrosion on tip with rich condition
What liter engine is this? Going over 4v is good but idle seems high depending on engine size
The following user(s) said Thank You: Rusty
- Rusty
8 years 5 months ago - 8 years 5 months ago #20653
by Rusty
It has a 2.0 litre V6 engine European model Maxima QX. The 4.3g/s is only since I cleaned it previous to that it was 2.2 - 2.6 g/s so cleaning may have made things worse or just made it honest. The problem with trims is only at idle because when rpms are above 1200 they float either side of 0 from apx (+/-) 0.8% to 3.2% and climb gradually all of these numbers are not under load. I am only using trims as a reference so the fact they improve with rpm makes me think the MAF might be bad. I might add the car is responsive but I can hear a slight miss, still its better than it was but she is a bit shuddery at idle. I can't see voltage when I drive her because my scan tool doesn't support it just g/s and my scope is laptop based and the cables are too short to reach the cabin. I will try and get better readings today. Thanks again
Last edit: 8 years 5 months ago by Rusty.
- Rusty
8 years 5 months ago - 8 years 5 months ago #20667
by Rusty
Hi Ben I went for a drive and went through the gears from idle she ranges from 3.1g/s @ 0% throttle and up to 48.9g/s @ 68% throttle in third and approximately 4300rpm,
- Ben
8 years 5 months ago #20671
by Ben
Well that doesn't seem good to me a 2.p engine should idle at about 2 grams +-.8 and at 100% throttle under load (accelerating) you should be able to reach at least 80 grams . How did you clean it?
- Rusty
8 years 5 months ago - 8 years 5 months ago #20691
by Rusty
Hi Ben, I used electrical contact cleaner but I think it just highlighted the problem. I cant get MAF cleaner anywhere local by local I mean 30 mile radius. I noticed on a section of the MAF there is a rectangular polished plate which looks like it has a small amount of corrosion either side of it. I think I need to replace the MAF. I will have to try and ship one from rock auto which will take over a month with customs but there is a difference of 200 euro and its the OEM Hitachi so worth waiting for. Is there anything else I can do to confirm, or do the numbers speak for themselves. Dar
Sent from my 5047Y using Tapatalk
8 years 5 months ago #20695
Replied by Andy.MacFadyen on topic Re:2001 Nissan maxima crank ref sensor corrosion on tip with rich condition
If badly fouled some types of MAF sensor don't return to within spec after cleaning, I mainly see Bosch analogue sensors on BMW diesels and have rarely had any luck cleaning them. The other ones I see are Fords and cleaning them often works.
- Rusty
8 years 5 months ago #20699
by Rusty
Hi Ben Nissan use a Bosch sensor on the primera diesel here which is the same model as the g35 in the states which is the same type of sensor which don't clean well either, I guess I am buying a MAF thanks again for all your help When I change it out I will post back with the result hopefully it will be good news because I am out of Ideas if not.
- Ben
8 years 5 months ago #20740
by Ben
Ahh yes no luck cleaning those...
- Rusty
8 years 5 months ago #20744
by Rusty
Yep thanks Ben
- Rusty
8 years 4 months ago #21075
by Rusty
hi Ben tried new maf now its opposite positive trims at idle and -10.2 lt at 2500rpm+
I presume this means new MAF must be faulty. I am going to run it through a test with the original MAF to see what HC'S and CO levels really are will let you know.
