2008 dodge ram 2500 heavy-duty laramie mega cab (D)- 5.7L smpi magnum 16v EZA
  • megaram08
  • megaram08's Avatar Topic Author
8 years 6 months ago #19928 by megaram08
all lights work power plugs work door locks door chime alarm all work getting power to everywhere but that's it doesn't start/crank/fuel pump won't come on/cicks/no starter engagement/will not link to obd2 or programmer, code u100,u0100, and a few more vin mismatch, not linking to abs/ficam/ecu/pcm/skimkey/remote start/bcm/dats link port also will not read codes after key on off of gauge check or diagnostic mode not sure what happened it's got me stumped
  • chief eaglebear
  • chief eaglebear's Avatar
8 years 6 months ago #19986 by chief eaglebear
Do you have power on pin 16 and a ground for pins 5and 4 also do you have a five volt ref line there may be more than one also good old powers and grounds for the ecm just my two cents lol
  • cheryl hartkorn
  • cheryl hartkorn's Avatar
8 years 6 months ago #19994 by cheryl hartkorn
can you talk to any module on the truck with the scanner?? do you have a scope to check the pins 6 and 14 at the data link connector?
