2014 Dodge Ram 1500 purge valve
  • journeyman
  • journeyman's Avatar Topic Author
8 years 6 months ago #19906 by journeyman
2014 Dodge Ram 1500 purge valve was created by journeyman
Need to know on the purge valve connector, should there be battery voltage, koeo with asd relay closed? I have 8 volts. Normal or do I need to look deeper? Can't seem to find the spec on it. 5.7l w/6spd trans.
  • cheryl hartkorn
  • cheryl hartkorn's Avatar
8 years 6 months ago #19910 by cheryl hartkorn
Replied by cheryl hartkorn on topic 2014 Dodge Ram 1500 purge valve
according to the wiring diagram the power wire comes straight from the pcm pin 94 dark blue and white and a constant ground at g206. what is the code your chasing?? have you bench tested the purge valve to see if it clicks?
  • Ro-longo
  • Ro-longo's Avatar
  • North Salt Lake, Utah
8 years 6 months ago #19911 by Ro-longo
Replied by Ro-longo on topic 2014 Dodge Ram 1500 purge valve
The purge solenoid is a positive side, pulse width modulated solenoid. the 8 volts you see is just the PCM switching the power to the purge valve. If you are just using a volt meter, then you are just seeing the average voltage. As cheryl hartkorn said, what is the issue you are having.
  • journeyman
8 years 6 months ago #19919 by journeyman
Replied by journeyman on topic 2014 Dodge Ram 1500 purge valve
Bench tested purge valve. No click. Put lab scope on wire & can see the pulse voltage. Purge valve fixed it. Thanks for all the info. Great forum
  • journeyman
8 years 6 months ago #19929 by journeyman
Replied by journeyman on topic 2014 Dodge Ram 1500 purge valve[FIXED]
THANKS
