Brake release then pop
  • Hockey4dad
  • Hockey4dad's Avatar Topic Author
8 years 6 months ago #19794 by Hockey4dad
Brake release then pop was created by Hockey4dad
Hello I’m a DIYer and have a question that someone could point me in the right direction.2005 Chevy Silverado 1500 4wd.. When I come to a complete stop, then give it the gas there is a pop/clunk sound,if I ease off ,not so much. I put the front on jack stands,because I thought it might be ball joints,everything tight..Wheel bearings ok, sounds like it’s comming from the front end.any thoughts on what else I could check?
8 years 6 months ago #19822 by Deltron
Replied by Deltron on topic Brake release then pop
How did you test the ball joints? On that truck, you want to jack up underneath the lower control arm to unload the joint, then use a pry-bar underneath the tire to lift the joint and check for movement.
The following user(s) said Thank You: Hockey4dad
8 years 6 months ago #19832 by Ben
Replied by Ben on topic Re:Brake release then pop
Also I know you said it sounds like front end but maybe check the u joint in the drive shaft as well they will pop on acceleration
8 years 6 months ago - 8 years 6 months ago #19834 by Andy.MacFadyen
Replied by Andy.MacFadyen on topic Brake release then pop
Brake pad/caliper moving in the guide bracket ? Did you check the propellor shaft joints ?
Last edit: 8 years 6 months ago by Andy.MacFadyen.
  • Hockey4dad
8 years 6 months ago #19870 by Hockey4dad
Replied by Hockey4dad on topic Re:Brake release then pop
Do I need to take the weight off of the 2 rear tires to properly check this?
  • Hockey4dad
8 years 6 months ago #19871 by Hockey4dad
Replied by Hockey4dad on topic Brake release then pop
I did not. Thanks I will check
  • Hockey4dad
8 years 6 months ago #19872 by Hockey4dad
I did unload the weight. Then checked for play everything ok on ball joints.
  • Hockey4dad
8 years 6 months ago #19873 by Hockey4dad
I did not check pad /caliber I will do that.
