No misfire counter in my 99 Durango?
  • Deltron
  • Deltron's Avatar Topic Author
8 years 6 months ago #19742 by Deltron
No misfire counter in my 99 Durango? was created by Deltron
I found myself bored a few days ago and I wanted to try and chase down this very slight stumble/miss that I have @ idle on my 99 Durango 5.9 magnum. I still haven't found it, but my concern here is that my Autel scanner and my Launch scanner are seemingly incapable of providing me with a misfire counter PID, in generic mode or enhanced. It's not inside the live data list, it's not inside the active tests menu(where i've seen it listed inside Snapon scanners for this gen Dodge).. I assume my only option here is to access mode 6, of which I have only 5 data parameters total that I can't decipher. So I turn to the scanner gods.. Where's my misfire counters?
8 years 6 months ago #19746 by Tyler
Replied by Tyler on topic No misfire counter in my 99 Durango?
With the Snap On, I find it under 'System Tests', called "Which Cylinder is Misfiring". System Tests is a different menu from Active Tests, because... reasons? :silly: I've never looked for it on an Autel, but I figure it'd be there somewhere. Sounds like you've searched up and down.
I'm pretty sure Mode $06 is gonna be a dead end. :( If it makes you feel any better, I've never had much luck with the Dodge/Chrysler misfire counter. Struggles with anything less than a dead miss.
  • chief eaglebear
  • chief eaglebear's Avatar
8 years 6 months ago #19763 by chief eaglebear
Replied by chief eaglebear on topic No misfire counter in my 99 Durango?
Dead on diagnostics has some good stuff on misfires I am studying that series right now you are right to try and get mode si data if you Kan also I think some kodes blok misfire kounters
