2001 Chevy Venture
- Bigfoote13
- Thank you received: 2
How does the engine run off idle? Plenty of power? Mostly just want to rule out an intake restriction (rats nest in the intake tube, plastic bag in the air filter, like that). Once the engine warms up, what do the IAC counts do?
To me it seems like the engine is suffering from genuine lack of air coming into the engine when cold. You can confirm this by creating a controlled vacuum leak and see if the idle comes up. If so, I'd suspect the IAC still isn't opening correctly, despite being replaced. Do you have bidirectional control of the IAC with a scanner? You can unbolt it and command the IAC back and forth, see if it moves. DON'T bolt it back up without retracting the pintle.
Speaking of, has anyone replaced the throttle body or gasket recently? It's possible to get the wrong one (or install it the wrong way) and create this issue.
- Bigfoote13
- TheTechWhisperer
- Thank you received: 47
The first thing I would look at is a custom PID list during those 1st 15 min, while looking at Fuel Trims, MAF, MAP, ECT, O2's, RPM, TPS. I know you said that you sprayed around for a vacuum leak, but with the cold start progressively getting better as it warm up, I cant help but think about a dried out or worn gasket in the induction system somewhere. Even if you dont have any external leaks, don't rule out internal vacuum leaks if it is a "V" motor with a lower plenum.
If you can grab some of those pid's during the event and then after it gets better, I would love to see them
"You will always find the greatest fulfillment in life when you are operating in the gifts God gave you"- Dad
National Director of Technical Training & Mechanical Operations - Express Oil Change & Tire Engineers
ASE Master L1 Tech
BMW Master Tech
Ford FACT Advanced Electronics Instructor
- TheTechWhisperer
ASE Master L1 Tech
BMW Master Tech
- Bigfoote13
TheTechWhisperer wrote: As techs, we ask each other for outside opinions to make sure we aren't going too far down a rabbit hole (at least I do). That being said, I am not trying to de-rail the IAC discussion, but lets take a step back for a sec... Remember that IAC is an output of the PCM, so before we go too far lets look at the inputs. I have seen other things cause engines to idle low, and the PCM raises the IAC count just to try and avoid stalling. My point is that the IAC deal may be a symptom and not necessarily the cause of the problem. Hopefully that makes sense (I am a teacher and I tend to over-explain things).
Sent from my LG-US701 using Tapatalk
- Bigfoote13
The van stayed running a idle this time, although it was very low. I did find the idle speed screw, it is nice to have one, and raised it to 600+ RPM. It was down to just over 500. I found no abnormal scan PIDS on the ones you mentioned Tech, (BTW what is your name?). There is a strange vacuum like leak sound coming from under the upper intake, coil area but no significant, abnormal fuel trim values, except when I induce an intake leak. Trims are down at 0 to 2% and raise to 8 to 12 when induced.
One other ? I have is about the IAC
- Bigfoote13
Continued... IAC computer control ?. Is there some problem with the PCM not adjusting the counts up and down during running speed? Just wondering,
Thanks, Doug
