Engine swap - crank but no start/no spark
- BseriesBro
1 year 8 months ago #79950
by BseriesBro
Engine swap - crank but no start/no spark was created by BseriesBro
Hello all I am brand new to the forum. My name is Chuck and I'm a novice, mostly backyard mechanic with am intermediate level of understanding lol. Now to the point!
I recently did a motor swap for a friend of mine on a 2004 Mazda 3 S with the 2.3 naturally aspirated. The old motor was working more like an oil pump then a combustion motor. The new motor was bought online on ebay and is also a 2.3 but out of a ford and configured differently. Example - accessories in different places.
Here is a list of things I had to swap from old motor to new.
- timing cover and crank sensor
- crank pulley
- water pump pulley
- serpentine belt tensioner assembly
- alternator
- oil pan
- ac compressor
- idler pulley
- valve cover (because coils were a different plug and old coils wouldnt mount in new cover)
- ignition coils
- manual flywheel and clutch
I had to swap all these things mostly to make the new motor "jive" with the old engine harness and to make the existing belts work.
As you probably know this particular motor is a giant pain to set the timing on. So I purchased the special timing tools and took extra care setting the timing. Motor rotates freely (but not too freely) by hand.
The job went beautifully as far as the physical mechanix. Car is all back together and job is clean.
NOW FOR THE MEAT! Car is only turning over(cranking) and will not start! Intermittently throwing 2 communication error codes. One for abs lost communication and the other for ipc cluster lost communication. I've pulled the coils and checked the resistance they're good but not getting any spark what so ever and can't figure out why. I've checked the obvious things like relays and fuses. PLEASE PLEASE PLEASE HELP!
- crank pulley
- water pump pulley
- alternator
- oil pan
- ac compressor
- idler pulley
- ignition coils
- bills4065
- Thank you received: 17
1 year 8 months ago #80020
by bills4065
Replied by bills4065 on topic Engine swap - crank but no start/no spark
When you turn the key to on- do your warning lights come on? - check engine light ? etc. etc.
- BseriesBro
1 year 8 months ago #80119
by BseriesBro
Replied by BseriesBro on topic Engine swap - crank but no start/no spark
Yes they do. See attached Pic. Even though the check Engine light stays on after cranking it has no dtc's except for the before mentioned u-codes
- bills4065
1 year 8 months ago #80270
by bills4065
I am assuming you can communicate with the car with a scan tool, since you said intermittent U codes. I would recheck all my connectors and ground connections since this was an engine swap.If still no start- I would try cranking car over and check at a fuel injector to see if you have pulsing control.Use a test light or noid light for this.
- ferris48
- Thank you received: 47
1 year 8 months ago #80302
by ferris48
Replied by ferris48 on topic Engine swap - crank but no start/no spark
I don't see a pictureYes they do. See attached Pic. Even though the check Engine light stays on after cranking it has no dtc's except for the before mentioned u-codes
- ferris48
1 year 8 months ago - 1 year 8 months ago #80303
by ferris48
Have you seen this:
diag.net/msg/m438upc23y4c4kotyhpzv0upne
cmp rides on 1.5v
ckp rides on 2.5v
Cam and crank signals are biased at around 2.5v
Unplug sensor KOEO, do you have these voltages? it's a quick test to check wiring integrity back to the computer.
ckp rides on 2.5v
Last edit: 1 year 8 months ago by ferris48.
