2010 CR-V Rack Leak?
  • Tutti57
8 years 6 months ago - 8 years 6 months ago #19434 by Tutti57
2010 CR-V Rack Leak? was created by Tutti57
Car failed inspection for leaking rack. I see this fluid here but wiped it and it's not coming back. Are these common leak locations and would this need to be replaced based on the pics?
Last edit: 8 years 6 months ago by Tutti57.
8 years 6 months ago #19480 by Tyler
Replied by Tyler on topic 2010 CR-V Rack Leak?
The last picture shows the return hose, right? That's a very common Honda problem, across just about every model. :lol: There's usually three separate sections return hose in the system (from the rack to the reservoir), and they all leak at those stupid wire clamps. Either that, or the hose hardens and sucks air, causing aerated fluid and pump noise.
As for the leak at the pinion... I'm not sure? It looks like the cap comes off, but I don't know what you'd torque it to, or where you'd get the seal/o-ring. :unsure: Might have a look at service info, see if they even list a procedure.
8 years 6 months ago #19504 by Ben
Replied by Ben on topic Re:2010 CR-V Rack Leak?
That's the lash adjuster don't disassemble it you'll have a mess on your hands! Personally I would clean it off and send it back for inspection if it only seaps as much as it looks like and doesn't do any dripping I would let it go!
8 years 6 months ago - 8 years 6 months ago #19506 by Andy.MacFadyen
Replied by Andy.MacFadyen on topic Re:2010 CR-V Rack Leak?
I agree wash it off -- no way that pinion leak a major leak. Leak from return hose clamps are common on a lot of car usually a wash down before inspection is good practice. Power steering system tend leak less if old style mineral fluid is used, adding stop leak can have a similar beneficial effect it plumps- up and re-softens the seals.
Last edit: 8 years 6 months ago by Andy.MacFadyen.
  • Tutti57
8 years 6 months ago #19557 by Tutti57
Replied by Tutti57 on topic Re:2010 CR-V Rack Leak?
Thanks. We'll start with a clean up.
