[FIXED] 1997 Honda Accord No Start
Noah wrote: I put VERY little faith in anything posted in online enthusiast forums. Obviously the same doesn't apply on THIS forum, but some of the advice people are giving and taking as gospel out there is scary.
Truth!
I like to think we know what we're talking about, anyway
- OldSchool
- Thank you received: 3
Here's where I'm at with this/to clarify my own thoughts, lol!
-Car tries to start but won't catch. Starter is spinning the engine over just fine.
-pulled trouble code: P1361
-Got lotsa fuel flowing at the loosened nut on the fuel rail.
-Car starts & keeps running when a steady supply of carb cleaner is injected in intake vac line.
-Combo cam/crank sensor tested at .52 ohms. way out of spec.
-Got injection pulse - verified by a noid. Pulse seems erratic & strength/brightness of light varies. Couldn't find injector pulse using a test light.
-For a few months, car had random occasions where it would bog down, but then start & run fine later - but now it won't start (without carb cleaner). Both probably ruling out the likelihood of jumped timing belt.
-today, after installing new main relay, it tried much harder to run, firing significantly more (which seems odd), and I was thinking that it just might stay running when I let go of the key. It didn't. (yeah, just thought of this and I'm going to try starting it one more time tonight, but this time, only letting the key turn back enough to disengage the starter and see what haps...)
That's about it:
I'm thinking that I have A. I have a short somewhere or b. that the crank/cam sensor is bad.
I'm burned out, and I am going to try to find someone with a scope to check this.
Thoughts?
Thanks!
P.S. Tyler, I was wondering how such a myth got started. And hey, how do I "give thanks" on the forum?
- OldSchool
The oil pressure switch is wired in parallel to the fuel pump relay, which means that it acts as a backup power source for the pump in case the relay fails. Contrary to the myth, this fuel pump will absolutely still get power from the relay with zero engine oil pressure.
About the bypass test. Sure, the Odyssey is a different vehicle, but I believe the CKP/TDC/CMP sensor design is the same. The wire color you're looking for is still the same, though, the orange/blue on the four-pin CKP sensor connector. I'm still thinking about the bypass test because, while you have injection pulse, it's weak/erratic. Wondering if this is adding up to our lack of fuel issue.
Very interesting that it runs better with a new main relay! That makes me question the whole TDC sensor thing, though it still sounds like we're chasing a fuel delivery problem. Not sure if I'll catch you in time, but if you do end up trying to start it again this evening, try holding the throttle open during cranking. Let me know if it makes any difference!
Oh yeah, you can give thanks to anyone by clicking the button at the bottom left corner of their post. It's a new feature with this version of the forums, loving it.
- OldSchool
1) a: Is there a cheap scope or other tool that I can buy/rent that will definitively tell me if it's the crank/cam sensor or not? b. Or perhaps some type of tool that I could connect to my laptop?
2) a) What would I have to replace to convert to the 94-95 ignition system (because the sensors are in the distributor)? Or b: is this a bad idea? LOL!
Thanks!
I know from talking to Andy MacFadyen, another member here, that there's even more affordable options out there. Apparently there's even Bluetooth scopes that connect to your smartphone! Starting a thread in the Diagnostic tools and techniques section would probably be the best place to start for recommendations. If you were to get a scope, it'd be very easy for us to coach you on hooking it up.
As for converting this to the older design, I'm not sure what that'd involve, exactly. You'd have to get the signals from the older distributor wired into the harness, obviously. The distributor connectors won't be the same, either, so you'd have to make that work somehow. I'm also not sure if the older distributor would mount up correctly, as the distributor shaft is keyed to the end of the camshaft.
IMO, I think you'd be happier with this repaired correctly (if it does come down to a TDC sensor, of course), as opposed to making something else work. I see 'cobbled' fixes at work all the time, and they usually cause more problems than they solve.
- rod747
- OldSchool
thanks everyone for all your help!
