Help locating coolant pressure (not temperature) sensor
8 years 6 months ago #19312 by Pinto
I am looking at wiring diagram for 2008 mini cooper 1.6L, the DME is grounding the fan relay even though engine cold and a/c off, there is 2 inputs for the DME unit one from coolant temp sensor and the other from coolant pressure sensor, any one familiar with Mini coopers chime in and tell me where to find it? I looked alldata, google...but couldn't locate it.
  • chief eaglebear
  • chief eaglebear's Avatar
8 years 6 months ago #19313 by chief eaglebear
Replied by chief eaglebear on topic Help locating coolant pressure (not temperature) sensor
You can do a pressure test on a cooling system I don't think I have ever come across a coolant pressure sensor I am not sure it has one the coolant is read from the ecm with a thermistor pressures of the coolant are dependant apon engine specs i.e. displacement application of the engine and other operating parameters
  • chief eaglebear
8 years 6 months ago #19314 by chief eaglebear
What is the dme and what input is causing it to keep fan ground side switched
8 years 6 months ago #19317 by Chad
8 years 6 months ago #19319 by Tutti57
chief eaglebear wrote: What is the dme and what input is causing it to keep fan ground side switched
It's BMWs version of ECU, PCM, etc.
8 years 6 months ago - 8 years 6 months ago #19320 by rockp2
Found this, hope it applies:
"Coolant pressure sensor
The coolant pressure sensor is fitted in the pressure line between the condenser and the evaporator. Depending on the sensor signal, the
air-conditioning compressor is regulated by the IHKA control module in the event of excessive refrigerant pressure. The junction box supplies the
coolant pressure sensor with voltage. The data is evaluated in the junction box electronics. The prepared data is sent across the body CAN
(K-CAN) to the IHKA control module."
workshop-manuals.com/mini/cooper_(r56)/l...t_heating/page_9071/
Last edit: 8 years 6 months ago by rockp2.
The following user(s) said Thank You: Pinto
8 years 6 months ago - 8 years 6 months ago #19327 by Pinto
Thank you guys for your input.
Rockp2, I guess the Coolant pressure sensor is just the refrigerant pressure sensor then, I thought it has to do with anti-freeze.
I am still working on this and I will keep you guys updated:
P173b = CAN coolant temp sensor invalid.
P112b = Engine coolant temp low.
Fan works continuously with ignition On or engine running regardless of coolant temperature, fan turns off when removing fuse F05 (5 amp).
Last edit: 8 years 6 months ago by Pinto.
8 years 6 months ago #19336 by rockp2
Pinto, I'm not certain there is not a engine coolant pressure sensor. That info I found on the internet. I'd check the sensor described against the wire diagram pole71 provided
8 years 6 months ago - 8 years 6 months ago #19337 by Ste
Last edit: 8 years 6 months ago by Ste. Reason: Wrong diagram
8 years 6 months ago #19341 by Ste
File Attachment:
File Name: Wiringdiag...data.pdf
File Size:915 KB
8 years 6 months ago #19356 by Pinto
Ste, your wiring diagram confirms that Coolant pressure sensor is indeed the refrigerant pressure sensor ( B161 ).
