Help..02ranger 3.0 misfiring
  • Shelbel
  • Shelbel's Avatar Topic Author
8 years 6 months ago - 8 years 6 months ago #19304 by Shelbel
Help..02ranger 3.0 misfiring was created by Shelbel
Need suggestions, 02 ranger 3.0, started all the sudden misfiring, horrible gas mileage, horrible gas usage. Have changed plugs,wires,coil,fuel filter,throttle position. Sensor,fuel injectors,done fule pressure check, cleaned maf sensor, 2catalytics, hose, was barely able to go 13 mph up hill, after throttle sensor was changed got better pic exceleration alot more power but still misfiring. Also was throwing po174 code, check engine light on.
Last edit: 8 years 6 months ago by Shelbel. Reason: Forgot something
8 years 6 months ago #19309 by Ben
Replied by Ben on topic Re:Help..02ranger 3.0 misfiring
What is your fuel pressure idling and what's the lowest it goes while accelerating (I feed the gauge up to windshield and close hood)
  • chief eaglebear
  • chief eaglebear's Avatar
8 years 6 months ago #19311 by chief eaglebear
Replied by chief eaglebear on topic Help..02ranger 3.0 misfiring
Hi sir I was thinking about your case I have learned you can have fuel pressure but not volume since everything has been changed sounds like a control problem or the fuel pump is working but under load that broken winding is not working hard enough just a thought
  • Shelbel
8 years 6 months ago #19362 by Shelbel
Replied by Shelbel on topic Help..02ranger 3.0 misfiring
I'm a ma'am not a sir (lol) thanks for your suggestion, my friend has been working on it for me, I have never seen a vehicle he couldn't fix, but this one has him stumped, he's the one that has been working on it and now kinda at a stand still. I'm gonna compression test tomorrow, I've also been told maybe intake manafold gasket. All these parts are really adding up, hopefully a fix is coming very soon.
  • Shelbel
8 years 6 months ago #19363 by Shelbel
Replied by Shelbel on topic Re:Help..02ranger 3.0 misfiring
I will have my friend check that tomorrow, we are really stumped on this one.
  • Shelbel
8 years 6 months ago #19934 by Shelbel
No luck, compression test all okay. Replaced intake manifold gaskets upper and lower, valve cover gaskets and cam shaft sensor/synchronizer. Still backfires and misfires. I don't get this...we changed around plug wires and it runs the same also when checking fuel injectors 2 out of the 6 doesn't change the motor at all when normally it would bog down, (the rest of them do. I cannot afford to keep buying parts that help nothin. ANY have done everything we can think of, my friend wants to try the mas sensor but Im not gonna buy another $90 part for nothing, I need advice any suggestions would be greatly appreciated
  • Shelbel
8 years 6 months ago #19935 by Shelbel
I don't understand how the when the plug wires are put on any which way how it runs and doesn't change no matter what way u switch em, can put em completely different than firing order and runs without bogging or any hesitation
I
8 years 6 months ago - 8 years 6 months ago #19938 by Noah
Replied by Noah on topic Re:Help..02ranger 3.0 misfiring
If you disconnect 2 injectors and nothing changes, then the engine isn't running on those 2 cylinders. A mass air flow sensor isn't going to change that. Could be as simple as having the plug wires on wrong still.
That truck has a waste spark system, so it fires 2 at a time. If you move the plug wires from one tower to the companion tower (the two that are firing in pairs) it wouldn't make a difference.
Find out which 2 cylinders are dead and focus there.
If it's 2 cylinders next to each other, you might want to consider a cylinder leak down test to rule out a head gasket type issue.
Last edit: 8 years 6 months ago by Noah.
The following user(s) said Thank You: chief eaglebear, Shelbel
Time to create page: 0.325 seconds
