07 saturn vue
- chief eaglebear
- Thank you received: 70
- juergen.scholl
- Active partschanger
- Thank you received: 462
What scanner are you using , does it provide misfire counter?The engine runs richer the higher the rpm go? How about engine temp sensor reading?
What's bank one doing while the trims are pegged out on bank two? The misfire codes make me suspect a valve adjustment issue, but the MAP sensor reading does sound pretty reasonable.
Somewhat unlikely, but the EGR could be stuck open. That'd definitely account for the rich trims and misfires. What the EGR position at idle? Around 1.00V is what we're looking for.
- chief eaglebear
- chief eaglebear
chief eaglebear wrote: Hi guys closing this one out customer took vehicle
Ah I'm sorry sir.
I dunno why some Vue's ended up with Hondoo engines? :lol: They're really conflicted cars - excellent engines, crap chassis.
- chief eaglebear
The upstream sensors will read 0 mA with a stoichiometric mixture. Rich will produce negative readings, lean will produce positive readings. Here's an example from ScanShare:
www.scanshare.io/share/SkAQl0NLiE6ixdCbU...,14,15,74,75,114,115
One very quick check that you can do is to compare the upstream air/fuel ratio sensor and the downstream O2 on the same bank. If the upstream sensor has negative (rich) readings, then the downstream better agree (over 800 mV).
As for the MAP sensor, there's a couple quick checks you can do there, too. At idle, fully warmed up with no electrical loads, the MAP should read less than 1.00V, usually closer to .9V. WOT will usually show 2.7 - 2.8V. You can also check rationality here by reading the MAP at KOEO. Again, should be around 2.8V.
- Tutti57
- Thank you received: 254
Is that map test specific to this vehicle or a good general test?Tyler wrote: What scanner are you using? I ask because the upstream O2's on these engines are air/fuel ratio (wideband) sensors. They don't produce a voltage signal like conventional O2's do, but rather a current reading in mA. Global OBD data can sometimes make this confusing and unclear.
- chief eaglebear
Tutti57 wrote:
Is that map test specific to this vehicle or a good general test?Tyler wrote: As for the MAP sensor, there's a couple quick checks you can do there, too. At idle, fully warmed up with no electrical loads, the MAP should read less than 1.00V, usually closer to .9V. WOT will usually show 2.7 - 2.8V. You can also check rationality here by reading the MAP at KOEO. Again, should be around 2.8V.
That's a pretty good rule of thumb for most Honda engines, IMO. Why 2.8V at atmospheric, when other makes are over 4V? Because Honda. :silly:
I have a Bosch code reader with pids and the upstream af ratio sensor explains why it was only showing o2sb2.2 and o2sb1.2 I believe it was showing the milli amps of the af sensors I will have to check that out but as for those other checks I will update asap
Yeah, that's kinda misleading, isn't it? :lol: FWIW, the open loop/closed loop behavior you're describing could be a PCM response to a dead misfire. I've seen other Honda's of this vintage react the same way, by open looping the bank with the misfire. Just something to keep in mind.
- chief eaglebear
chief eaglebear wrote: Watched a scanner danner video and a Wells video on wide bands very interesting I do not have a scan tool with af pids on it 3volts and 3.3 volts usually a scan tools needed to diagnose AF ratio sensors provides an even more precise fuel control from a wider range of sense
If your scanner shows the mA PID for the upstream air/fuel ratio sensors, then you can probably get by with the scanner you have! I've got a thread going on this type of sensor, if you're looking for more info:
www.scannerdanner.com/forum/diagnostic-t...-testing-thread.html
Here's an example of the PIDs you're likely to see during a test drive. 'Lambda' in this case translates to 'Equivalence Ratio' in Global data.
www.scanshare.io/share/OrtyMv5LFkWuOWHfTccMZw
- chief eaglebear
- chief eaglebear
- chief eaglebear
The 'Inc' on the Readiness Monitors probably means incomplete, in that it just hasn't run yet. All the monitors get reset when you clear codes, so it's not surprising that some of the monitors haven't ran yet. Stuff like misfire codes will also prevent monitors from completing. I'm not sure which Dash Integration code you have? I doubt that has anything to do with it.
Which diagram did you find on BBB? This is the one I found for the 3.5L engine:
- chief eaglebear
