1998 5.7l V* Misfire
- randall.sick
8 years 6 months ago #19186
by randall.sick
My rides, 1998 Chevy Tahoe 5.7l
1999 Chevy S10 2.2l
1998 5.7l V* Misfire was created by randall.sick
So guys n gals, my last post was about a P0300 code on my 98 Tahoe. Installed a new aftermarket distributor, (after a whole mess load of other part replacements) and it seemed to be fine.
Today I drove to the store, parked, went in, came out, started it up and it idled rough. I limped it home when the SES light came on. and then flashed, then stayed solid, then flashed again.
I plugged my Solus into it and read the obdII codes and i have a P0300 again. Only this time I check the misfire cycles and #2 and #8 cylinders are having problems.
I noticed my spark advance was at 21 degrees as well
engine rpm was 600 rpms at idle
Coolant was 170 F
MAF was 6.57 g/s
load was 3%
MAP 10 inHg
Closed loop on egr
this was a 4 minute run time for the test.
I will admit, I am not a professional tech, so i need help.
Any ideas why only #2 and #8 are problematic?
Coolant was 170 F
MAF was 6.57 g/s
load was 3%
MAP 10 inHg
Closed loop on egr
1999 Chevy S10 2.2l
- derekoliveira
8 years 6 months ago #19189
by derekoliveira
Replied by derekoliveira on topic 1998 5.7l V* Misfire
So is a stedy misfire? Did you check spark for does spark wires(2 and
- derekoliveira
8 years 6 months ago #19190
by derekoliveira
Sorry...and nr 8 cylinder?
- randall.sick
8 years 6 months ago #19202
by randall.sick
1999 Chevy S10 2.2l
Replied by randall.sick on topic 1998 5.7l V* Misfire
Yes, both have spark. The light was stronger on #8 than #2 but still good spark.
1999 Chevy S10 2.2l
- derekoliveira
8 years 6 months ago #19203
by derekoliveira
Did you check both spark plugs. If they are ok next you can check if injectors are ok!
- randall.sick
8 years 6 months ago #19204
by randall.sick
1999 Chevy S10 2.2l
Yes, both plugs are good. I was afraid of the injectors bc it's the spider system, and I don't know how to do it without removing them.
Can I use my snap in tool to do it?
1999 Chevy S10 2.2l
- derekoliveira
8 years 6 months ago #19224
by derekoliveira
I'm not familiar with American cars, but you have access to the injector plugs and you can see if there is power and control. You can make a inj. balance test and you can watch Paul Danner (ScannerDanner) videos about it!
- randall.sick
8 years 6 months ago #19248
by randall.sick
1999 Chevy S10 2.2l
Ok. Thanks.
1999 Chevy S10 2.2l
- Ro-longo
- North Salt Lake, Utah
- Thank you received: 43
8 years 6 months ago - 8 years 6 months ago #19293
by Ro-longo
Replied by Ro-longo on topic 1998 5.7l V* Misfire
I suspect you have a bad distributor cap.
as you can see in the image #2 and #8 run next to each other in the cap and a crack can form inside the cap causing a misfire .
Watch Paul demonstrate how to test to cap.
Last edit: 8 years 6 months ago by Ro-longo.
- derekoliveira
8 years 6 months ago #19305
by derekoliveira
knowledge is a weapon (good one)!
- randall.sick
8 years 6 months ago #19360
by randall.sick
1999 Chevy S10 2.2l
Replied by randall.sick on topic Re:1998 5.7l V* Misfire
I changed out the cap and she purrs like a flowmaster kitten! Thanks so much for your help, that cured my ail!!!!!!!
Sent from my SM-G955U using Tapatalk
1999 Chevy S10 2.2l
