Wont stay running. And respond to the throttle
  • gerber
  • gerber's Avatar Topic Author
8 years 7 months ago #18987 by gerber
2000 lincoln navigator 5.4
Hard to crank and wont stay running.. i have to keep the gas pedal press in.. but stay running really bad. And wont respond to the throttle. Only code is
P1131.. but i think is because 1 exhaust bolt is broke. .
I put a good maf sensor because was dusty and cont get clean. With the spray..
Fuel presure with swich on engine off. Is 38. And running is 43. .. got new Motorcraft spark plugs.. and all 8 coils are new.. air filter. Fuel filter..i disconnect the 2 exhaust pipes because my be the cats.. but still the same. Any help.. God bless you guys.
  • cheryl hartkorn
  • cheryl hartkorn's Avatar
8 years 7 months ago #19004 by cheryl hartkorn
Replied by cheryl hartkorn on topic Wont stay running. And respond to the throttle
is the idle air control valve stuck closed? if you have to hold the throttle down during cranking to get it to start its pointing toward that.
  • gerber
8 years 7 months ago #19009 by gerber
Thanks for responding. . It wont give a code?...
I remove the idle air control valve.
It don't looks dusty. There is any way to find out if its open or close.
Thanks.
Time to create page: 0.258 seconds
