Idle Issues (1990 Buick Electra Park Avenue 3.8L 3800 Series 1)
  • Ben
  • Ben's Avatar Topic Author
8 years 7 months ago #18961 by Ben
I assume this does not have a maf? A quick test Try disconnecting your upstream oxygen sensor and see if straightens out
The following user(s) said Thank You: Dyllan.Love334
  • cheryl hartkorn
  • cheryl hartkorn's Avatar
8 years 7 months ago #18969 by cheryl hartkorn
how hard is it to check fuelpressureon this car? see what your losing when the stall happens....
  • Ben
8 years 7 months ago #19068 by Ben
Ok so with upstream oxygen sensor disconnected (thats the 1 in the manifold) it still don't run right correct?you said this had a sensor before the throttle body?
  • Ben
8 years 7 months ago #19098 by Ben
Ok you don't have a way to read live data on obd1 do you?
8 years 7 months ago #19105 by juergen.scholl
As you do not have neither data nor the required tools for some basic testing you´ll need a different approach:
How do your plugs look like? Any clues there, signs of lean mixture or engine running hot?. If you feather the accelerator pedal it won't stall?
  • Ben
8 years 7 months ago #19175 by Ben
I think your going to need to test them hot and the resistance will change with temp. However I would first check for spark when it is warmed up and running rough use a pair of insulated pliers and remove 1 plug wire from the coil pack at a time and note if engine idles worse or no change and make sure there is a spark arcing across coil pack when that wire is off(do not remove from the wire from plug you will get a jolt of a lifetime, dont ask me how I know) you'll either find which cylinder is dead or you'll find 1 coil pack isn't working
