ecu grounds
10 years 4 weeks ago #2046 by gil
ecu grounds was created by gil
I've got a 2010 toyota tacoma 2.7L with a intermittent no start when it is hot soaked. I have narrowed it down to a loss in spark (igt signal from the ecu). I have a good cam and crank input signal to the ecu. Proper Immobiliser input and output to the ecu. As i scope the igt signal outputs from the ecu, i would get 1-4 igt signal output randomly cutting in and out intermittently, causing an extended crank or a no start. As i check my computer grounds during cranking i get 600mv as a maximum reading. Is that an acceptable voltage while cranking??
10 years 3 weeks ago #2089 by Tyler
Replied by Tyler on topic ecu grounds
600mV? That does seen excessive... Are you measuring this with a multimeter?
If you wanted to prove that out, you could try adding a redundant ground to the wire you're seeing high voltage on, and see if the readings improve. If your hot soak symptom goes away, then you're on the right track ;)
10 years 3 weeks ago - 10 years 3 weeks ago #2116 by gil
Replied by gil on topic ecu grounds
thx for the reply. I used a scope to measure it. I did add a few extra ground. The weather is a bit cooler where I am. Im just waiting for a nice day to see if it corrected this problem
Last edit: 10 years 3 weeks ago by gil.
10 years 3 weeks ago #2127 by Tyler
Gotcha. I do sometimes see higher spikes on a scope trace during cranking, but they're very fast, and mostly amount to noise. Yours sounds like a more steady, consistent reading.
Thanks for keeping us updated!
