P0202 P0302
  • autojoe
8 years 7 months ago #18901 by autojoe
P0202 P0302 was created by autojoe
If you have a single cylinder misfire code and a injector control circuit fault for the missing cylinder..... Do you focus on the injector control circuit fault causing the single cylinder misfire?
8 years 7 months ago - 8 years 7 months ago #18902 by bruce.oliver
Replied by bruce.oliver on topic P0202 P0302
That all depends on how it's misfiring. Is it a constant misfire? Or intermittent?
But I would certainly check the injector and circuit for the injector, which is generally straight forward. Checking the coil is generally quick and easy as well. I would likely do a relative compression test as well.
Are you a technician? Is this a personal car? Or customer play? What is the car and engine?
Last edit: 8 years 7 months ago by bruce.oliver.
Time to create page: 0.219 seconds
