Po571 Chevy 2500 6.6 2008
- chief eaglebear
- Thank you received: 70
Based on your test at the light blue/white wire, we can say that half of the switch is operating correctly (at the time you tested it, anyway). This is your basic pull up switch input - the light blue/white won't have power on it until the switch is closed. The other half of the switch works the same way. With the switches closed, pin D purple and pin A light blue/white should show 12V or close to it.
Before you go too far in your pinpoint testing, you might have a glance at scan data. Both of these switches have corresponding PIDs which may be beneficial. Here's a shot off a known good '08 GMC 3500 that uses the same switch:
- chief eaglebear
- chief eaglebear
chief eaglebear wrote: Hi as far as I know the brake switch is in question I am not sure what wave forms are good and which ones are bad and also I do not know how any of those would effect the shutting off of cruise control and put service brakes soon light I think I am missing the strategy being used and exactly what parts of circuit to test I do not understand why the 1v ignition sign or any of those waveforms I have no idea how they would pertain to this code and why its kicking off cruise control and putting brake message on dash I do see the brake switch gets signal from bcm I would test at that point I am not thinking logically or do not know what to test on that switch I watched some videos where the same truck received a new brake switch and it cleared the code but I am not gonna just change the switch unless I know exactly why I am doing it thank you
Nah, you're thinking logically - you don't wanna throw parts at it!
I don't have Mitchell in front of me, so I don't know the exact strategy at work, but I can take a guess. The brake switch has two switches inside it, electrically independent of each other. One reports to the BCM, and one reports to the TBCM/ECM/TCM/PTO. These are both pull up switches if you want to refer to Engine Performance Diagnostics.
Both switches will change state when you step on the pedal. My guess is that the BCM and ECM are watching BOTH switches at the same time, and this code is setting when one switch or the other didn't change state when it should have. That's where the scan data comes in - if you're stepping on the pedal and you don't see 'BPP SIGNAL' or 'TCC/CC BRAKE PDL SW' change, then you're witnessing the problem.
Again, just a guess, but I'm betting the issue is with the 'TCC/CC BRAKE PDL SW', or the part of the switch that reports to the ECM/TCM. You get all those messages on the dash because the ECM/TCM no longer trusts it's brake pedal input, and is forced to turn the cruise off as a safety precaution.
I dunno how intermittent this problem is, but I'd suggest watching scan data first to see what's going on with those sensors when the code sets. You could also use a DMM connected to the purple or light blue/white wires and cycle the brake pedal repeatedly or wiggling the connector. If you catch either switch not changing state, you've found the problem.
- chief eaglebear
- chief eaglebear
- chief eaglebear
- chief eaglebear
chief eaglebear wrote: I think the hard part will be getting to bcu I might need to do some piercing
You can totally go to the ECM and BCM if you want.
For example, if you end up finding a failed brake switch, you can do bypass testing. Watch those two PIDs on the scanner, and short across pins C and D, or pins A and B. One PID or the other should change state as you apply the short, as this is exactly what the switch does.
Don't let the diagram make this look more complicated than it is.
- chief eaglebear
- chief eaglebear
Very interesting that I got an '08 GMC 2500 with the exact same complaint. :lol: It actually does have a bad brake switch. I can post scan data when I get home tonight. Are you sure you're not in Kansas? :silly:
- chief eaglebear
Thanks for keeping up updated!
- chief eaglebear
chief eaglebear wrote: I did not argue but kinda felt the same thing I could not put it together I did ask a couple times.?? I also asked if they took it for a test drive to see if it was still kicking off cc they did not ??
Eh, sounds like it was out of your hands! :silly: Maybe you'll have another shot at it if it comes back again?
On the '08 2500 I saw last week, I found the right data list to watch:
I finally caught it acting up when I'd tap the brake pedal the right way. CC would kick off, wouldn't engage again, and the code would go to 'Current DTC'.
You can see the 'BPP CIRCUIT SIGNAL' shows applied up to frame 300, while the other brake pedal PIDs show released. :silly:
- chief eaglebear
chief eaglebear wrote: Ah OK I see those waves and those circuits I wonder I would go directly x3 13 and x5 b1check voltage?
Definitely. I dunno how tough the BCM is to dig out of this truck... underneath the steering column, IIRC?
