2014 Dodge Caravan Misfire P0305
- omar3476
2014 Dodge Grand Caravan 3.6L SXT
initial code was P0303, was due to burnt exhaust valve....replaced head. after repair still has misfire but now it has moved to P0305 which is the next cylinder over in the same bank/head. i dont know if maybe i got a bad head from the dealer or something is not in line on my side. i did a relative compression test that is attached and what sticks out to me is cylinder 5 will give 2 good rotations and then a bad 1, it keeps this pattern for as long as you crank. before doing this relative compression test i moved coils/plugs/injectors around with no change. also, passes leakdown test. cam lobs look fine, new rockers/lifters were installed with new head. what would you recommend i check next?
- Ben
- Thank you received: 215
Ben wrote: ...if you have a pressure transducer a running compression test may help with Tyler's overlay program (that he still hasn't shared with the rest of his best friends on here cough cough)...
:lol: You KNEW I'd read this thread! Truthfully, it's not because I don't want to share, just a big legal concern that I don't want to bring to SD.com or the forums.
You could also try a vacuum gauge on the manifold at idle. I'm sure you'll see some twitching of the needle, but I'd be interested to see if you get pressure pulses in the intake during the misfire. That'd suggest an intake valve that is sticking open. You could also put your hand over the throttle (with the throttle wide open) and see if you feel pressure pulses during cranking.
The same could be done at the tailpipe, but I'm not sure you'd feel it? Just because of the length of the exhaust.
- dbadge
- Ben
Lol I'm under the impression is was either licensed as a freeware or shareware if you open the about tab it will say its licensing type and if it's either freeware or shareware you can legally share it as long as your not selling it.
- juergen.scholl
- Active partschanger
- Thank you received: 462
WOT while cranking will give you relative compression as well, as long as the engine does not start (it shouldn't at WOT in clear flood mode, otherwise disable the injectors).
- PDM
- Thank you received: 56
Only thought I have to add is that it could be a collapsed lifter (or whatever you would call it on an overhead cam) and the "every 3rd" issue is oil pump / pressure related.
