91 s10 4.3 no power to fuel pump
  • gregster
  • gregster's Avatar Topic Author
8 years 7 months ago #18545 by gregster
91 s10 4.3 no power to fuel pump was created by gregster
Hi with key on the ecm green white wire has 11.70 volts w/o relay. With relay same wire is only reading 0.07 volts. Black and white wire is good ground.fuel pump works when org and grey wire is jumped. Any ideas?
Sent from my SM-G930T using Tapatalk
8 years 7 months ago - 8 years 7 months ago #18551 by Chad
Replied by Chad on topic 91 s10 4.3 no power to fuel pump
It sounds like you have a voltage drop on the DK GRN-WHT wire. With the relay removed, you have 11.7 volts on the DK GRN-WHT wire. Will it light an incandescent test light?
This video explains voltage drops using a starter as an example.
Last edit: 8 years 7 months ago by Chad.
  • gregster
8 years 7 months ago #18552 by gregster
Replied by gregster on topic Re:91 s10 4.3 no power to fuel pump
Hi, my light didn't light, multimeter still showing 11.7 volts. didn't see a video attached to your reply. Thanks
8 years 7 months ago - 8 years 7 months ago #18553 by Chad
Replied by Chad on topic Re:91 s10 4.3 no power to fuel pump
A youtube search of " Multimeter basics, voltage and resistance tests (a free SD Premium video) " should find the video I was referring to. A search of "voltage drop testing" will net you many more.
A bad wire can show a voltage when there is nothing USING that voltage, but drop significantly when a load is added to the circuit. If you try to light the test light AND read the voltage at the same time, you will see the voltage drop. Connect your meter and watch the 11.7 volts. Now, add the test light while watching the voltage. Did the voltage drop? Now, move the the other end of the DK-GRN wire (at the ECM) with the volt meter. Try to light the test light at the relay socket. Did the voltage drop at the ECM?
  • gregster
8 years 7 months ago #18556 by gregster
Replied by gregster on topic Re:RE: Re:91 s10 4.3 no power to fuel pump
pole71 wrote: A youtube search of " Multimeter basics, voltage and resistance tests (a free SD Premium video) " should find the video I was referring to. A search of "voltage drop testing" will net you many more.
I put test light on at socket and volts did drop, put meter at ecm g/w wire and volts also dropped.
8 years 7 months ago #18560 by Chad
If you are showing a voltage drop at the ECM, then we need to check the power feeds INTO the ECM for a drop. Pins A6, B1, and C16.
8 years 7 months ago - 8 years 7 months ago #18564 by Tyler
Replied by Tyler on topic Re:RE: Re:91 s10 4.3 no power to fuel pump
pole71, I'm really not trying to be a jerk here. :blush: But, don't the GM fuel pump relay control circuits work this way by design? There's a bias voltage present on the dark green/white wire, as a circuit check on the control side of the relay.
This video is what I'm referring to:
Or, is this old news? 'Cause I'm sorry if it is! :silly:
Will the dark green/white wire light a test light during cranking? Or, during the key on fuel pump prime.
Last edit: 8 years 7 months ago by Tyler.
8 years 7 months ago #18565 by Chad
Thank you, Tyler. There's no being a jerk about it.:cheer: Good call. I was un-aware of a bias voltage, being here. I was assuming the 11.7 volts was while trying to crank.
Thanks for the video and helping to fill in the gaps in my knowledge. I know there are many. But, I learn more every single day.
  • gregster
8 years 7 months ago #18580 by gregster
pole71 wrote: Thank you, Tyler. There's no being a jerk about it.:cheer: Good call. I was un-aware of a bias voltage, being here. I was assuming the 11.7 volts was while trying to crank.
Hi, so should I check power going in to ecm still, or is this normal? Should i check grn/white wire with light while cranking? Thanks
8 years 7 months ago #18585 by Chad
Check the grn/white wire while cranking. You should see battery voltage and it should light the test light.
8 years 7 months ago #18598 by David56
pole71 wrote: Check the grn/white wire while cranking. You should see battery voltage and it should light the test light.
Ok . Passed I went out today to fine my problem. Placing my hand on the fusebox in the back. It was hot. So I opened it and I think I found the source. Turns out my number 58 relay was very hot. Unplug the relay but when I put it back it started snapping. Then I could here things coming on. Seconds later I heard a pop and everything shut down. That's were I am. Thanks. Dave
Sent from my LGL52VL using Tapatalk
8 years 7 months ago #18607 by Chad
Can you tell us what, or where specifically, Relay 58 is?
8 years 7 months ago #18609 by David56
pole71 wrote: Can you tell us what, or where specifically, Relay 58 is?
Lighter. Really. This isn't my first. I am 63 but I worked on these northstars when no one would. Been a while. The poping noise stopped everything. Nothing works not even dash
Noise sounded like it came from trunk. Thanks
8 years 7 months ago #18610 by David56
58 relay is in under back seat. In fusebox a twin to under hood. Thanks
8 years 7 months ago - 8 years 7 months ago #18614 by Chad
David56 wrote: Ok . Passed I went out today to fine my problem. Placing my hand on the fusebox in the back. It was hot. So I opened it and I think I found the source. Turns out my number 58 relay was very hot. Unplug the relay but when I put it back it started snapping. Then I could here things coming on. Seconds later I heard a pop and everything shut down. That's were I am. Thanks. Dave
My apologies, David56. But you have confused me, a little bit. :unsure: This thread was started by gregster for a 1991 s10. No power to the fuel pump. I thought I was replying to gregster and his S10.
If you need help on a different vehicle/problem, I encourage you to start a new thread stating your Year, Make, Model, Engine size, and a description of the problem you are having. :) This will help in minimizing any confusion.
8 years 7 months ago - 8 years 7 months ago #18616 by Chad
David56, I found your thread.
www.scannerdanner.com/forum/post-your-re...-no-crank.html#18522
I will respond on it, soon.
  • gregster
8 years 7 months ago #18656 by gregster
Ok there is no light at grn/wht wire when cranking. There is power at b1 a6 c16. Hopefully you get this old how other person is on my thread. Thanks Greg
8 years 7 months ago #18663 by Chad
When you first turn the key to the "On" position (without cranking), the ECM should power the g/w wire for 2 seconds, then turn off. Does it?
  • gregster
8 years 7 months ago #18675 by gregster
pole71 wrote: When you first turn the key to the "On" position (without cranking), the ECM should power the g/w wire for 2 seconds, then turn off. Does it?
grn/wht wire doesn't light up at all when key is turned on.
8 years 7 months ago #18681 by Chad
Since you have power on A6, ,B1, and C16, but get no power on the A1(g/w wire) when the Key is first turned on, or while cranking, I believe this is pointing to a bad ECM.
As a final check, I would verify good grounds on A12 and D1.
Does anyone have a second opinion?
Time to create page: 0.495 seconds
