2004 Seville stall, no crank.
  • David56
  • David56's Avatar Topic Author
8 years 7 months ago #18522 by David56
Re:Need service info? Check here! was created by David56
Ok I bought a 2004 cadillac Seville. Ran very good for 3 days. I pull in to shopping center car cuts off. I try to restart with no luck. Now next day car wont do anything. Check battery 12.6. Check up front at fuse box 12.6. Check all fuses fine. Buy a new starter because the one in it with my unionbox does nothing. Now I am sure its a ground. Dash lights up airbags working. Everything seems in order. Car does nothing. Can you help an old man out here. Thanks. Dave
Sent from my LGL52VL using Tapatalk
8 years 7 months ago #18528 by arbez
Replied by arbez on topic Re:Need service info? Check here!
David56 wrote: Ok I bought a 2004 cadillac Seville. Ran very good for 3 days. I pull in to shopping center car cuts off. I try to restart with no luck. Now next day car wont do anything. Check battery 12.6. Check up front at fuse box 12.6. Check all fuses fine. Buy a new starter because the one in it with my unionbox does nothing. Now I am sure its a ground. Dash lights up airbags working. Everything seems in order. Car does nothing. Can you help an old man out here. Thanks. Dave
David,
You should of started a new topic. Maybe an admin will do it for you.
Here is a wiring diagram for your starter circuit:
www.revbase.com/BBBMotor/Wd/DownloadPdf?id=79834
From your description it sounds like you have 2 issues, stalled & will not crank.Is this one of those starters under the intake manifold? If so, I would start at the starter relay & check powers & grounds. The starter should have constant power to the large cable, switched power to the small wire & be grounded to the engine/trans. Check the I/O's to the relay & let us know what you are missing.
Lets get the engine cranking, then move on to the stalling.
Good luck ...
8 years 7 months ago #18541 by Noah
Replied by Noah on topic 2004 Deville stall, no crank.
I moved this to your own repair question thread. No big deal, but i did mislabel the title. Trying to change DeVille to Seville, my fault. Sorry about the confusion.
8 years 7 months ago #18617 by Chad
Replied by Chad on topic 2004 Deville stall, no crank.
David56 wrote: Ok . Passed I went out today to fine my problem. Placing my hand on the fusebox in the back. It was hot. So I opened it and I think I found the source. Turns out my number 58 relay was very hot. Unplug the relay but when I put it back it started snapping. Then I could here things coming on. Seconds later I heard a pop and everything shut down. That's were I am. Thanks. Dave
8 years 7 months ago #18618 by Chad
David56 wrote:
pole71 wrote: Can you tell us what, or where specifically, Relay 58 is?
Lighter. Really. This isn't my first. I am 63 but I worked on these northstars when no one would. Been a while. The poping noise stopped everything. Nothing works not even dash
Noise sounded like it came from trunk. Thanks
8 years 7 months ago #18621 by Chad
David56 wrote: The poping noise stopped everything. Nothing works not even dash
Do you have power on any of the fuses in the fuse block under the rear seat?
  • David56
8 years 7 months ago #18636 by David56
Replied by David56 on topic Re:RE: 2004 Deville stall, no crank.
No but I found 6 wires with black on them. Wires are all orange. 2 big ones. 4 little one bottom of box.
8 years 7 months ago #18637 by Chad
Replied by Chad on topic Re:RE: 2004 Deville stall, no crank.
David56 wrote: No but I found 6 wires with black on them.
When you say "black on them", are you referring to a stripe? Or, do the have black on them because they have been burnt?
What about the Underhood Fuse Block? Is there any power there? If not, what about the battery?
  • David56
8 years 7 months ago #18640 by David56
Replied by David56 on topic Re:RE: Re:RE: 2004 Deville stall, no crank.
Ok first its blue. Current in rear but none in the front. Battery was 12.7 now 5
  • David56
8 years 7 months ago #18644 by David56
They are not burnt. Last night it looked burnt. Bluing of some kind. Their was a loud noise sounded like from trunk or under car. That's when everything went off.
  • David56
8 years 7 months ago #18652 by David56
I put car back on charge. Back fusebox #10 & #23 do not light everything else does. In the front fusebox the following do not light #21 #16 #11 #20 #15 #19 #14 #13 #5 #6 #9 #10 . dash lights up again.
8 years 7 months ago #18664 by Chad
8 years 7 months ago #18665 by Chad
8 years 7 months ago #18666 by Chad
David56 wrote: In the front fusebox the following do not light #21 #16 #11 #20 #15 #19 #14 #13 #5 #6 #9 #10 .
Is this with the Key On? Or, off?
  • cheryl hartkorn
  • cheryl hartkorn's Avatar
8 years 7 months ago #18667 by cheryl hartkorn
Replied by cheryl hartkorn on topic Re:RE: Re:RE: Re:RE: 2004 Deville stall, no crank.
looks like you might have a bad ignition 1 relay in the front fuse box. what turns that relay on??
8 years 7 months ago #18670 by Chad
cheryl hartkorn wrote: looks like you might have a bad ignition 1 relay in the front fuse box. what turns that relay on??
Key in START or RUN
  • David56
8 years 7 months ago #18698 by David56
Replied by David56 on topic Re:Need service info? Check here!
Dave56. The dummy with the cadillac Seville. 2004 Northstar. Was driving to store when car just shut down. Cranked but no start. Towed home. Started checking my fuses seem fine. Next I checked voltage. 12.7 battery went to the front 12.7. Put the key in and nothing. Sometimes dash lights up and sometimes nothing. Went to fusebox in the back. #58 relay was hot . pulled it out then put it back. Relay started poping. Looking for ecm . looked under glovebox don't see it. While checking on that something turned on under dash drivers side. Seconds latter it shut down . where is the ecm please. Lost and found. Thanks
8 years 7 months ago #18699 by Noah
Replied by Noah on topic Re:Need service info? Check here!
David56 wrote: Dave56. The dummy with the cadillac Seville. 2004 Northstar.
Don't be too hard on yourself.
I think the PCM is under the air cleaner box in it's own compartment.
I moved this question to your own existing thread. Keeping all your questions and tests performed in one thread helps others follow the flow of your diagnosis and keeps the forums from getting cluttered.
No harm, no foul. ;)
  • David56
8 years 7 months ago #18706 by David56
Yes that's the only place. Box in front nothing in middle works.
  • David56
8 years 7 months ago #18716 by David56
Yes power in backseat box. Just pulled ecm never seen a green and white wire.
