2004 Seville stall, no crank.
- David56
Sent from my LGL52VL using Tapatalk
- arbez
- Thank you received: 53
David56 wrote: Ok I bought a 2004 cadillac Seville. Ran very good for 3 days. I pull in to shopping center car cuts off. I try to restart with no luck. Now next day car wont do anything. Check battery 12.6. Check up front at fuse box 12.6. Check all fuses fine. Buy a new starter because the one in it with my unionbox does nothing. Now I am sure its a ground. Dash lights up airbags working. Everything seems in order. Car does nothing. Can you help an old man out here. Thanks. Dave
David,
You should of started a new topic. Maybe an admin will do it for you.
Here is a wiring diagram for your starter circuit:
www.revbase.com/BBBMotor/Wd/DownloadPdf?id=79834
From your description it sounds like you have 2 issues, stalled & will not crank.Is this one of those starters under the intake manifold? If so, I would start at the starter relay & check powers & grounds. The starter should have constant power to the large cable, switched power to the small wire & be grounded to the engine/trans. Check the I/O's to the relay & let us know what you are missing.
Lets get the engine cranking, then move on to the stalling.
Good luck ...
- Thank you received: 1139
David56 wrote: Ok . Passed I went out today to fine my problem. Placing my hand on the fusebox in the back. It was hot. So I opened it and I think I found the source. Turns out my number 58 relay was very hot. Unplug the relay but when I put it back it started snapping. Then I could here things coming on. Seconds later I heard a pop and everything shut down. That's were I am. Thanks. Dave
David56 wrote:
Lighter. Really. This isn't my first. I am 63 but I worked on these northstars when no one would. Been a while. The poping noise stopped everything. Nothing works not even dashpole71 wrote: Can you tell us what, or where specifically, Relay 58 is?
Noise sounded like it came from trunk. Thanks
David56 wrote: The poping noise stopped everything. Nothing works not even dash
Do you have power on any of the fuses in the fuse block under the rear seat?
- David56
No but I found 6 wires with black on them. Wires are all orange. 2 big ones. 4 little one bottom of box.pole71 wrote:
David56 wrote: No but I found 6 wires with black on them.
When you say "black on them", are you referring to a stripe? Or, do the have black on them because they have been burnt?
What about the Underhood Fuse Block? Is there any power there? If not, what about the battery?
- David56
Ok first its blue. Current in rear but none in the front. Battery was 12.7 now 5pole71 wrote:
- David56
They are not burnt. Last night it looked burnt. Bluing of some kind. Their was a loud noise sounded like from trunk or under car. That's when everything went off.David56 wrote:
- David56
I put car back on charge. Back fusebox #10 & #23 do not light everything else does. In the front fusebox the following do not light #21 #16 #11 #20 #15 #19 #14 #13 #5 #6 #9 #10 . dash lights up again.David56 wrote:
David56 wrote: In the front fusebox the following do not light #21 #16 #11 #20 #15 #19 #14 #13 #5 #6 #9 #10 .
Is this with the Key On? Or, off?
- cheryl hartkorn
- Thank you received: 130
cheryl hartkorn wrote: looks like you might have a bad ignition 1 relay in the front fuse box. what turns that relay on??
Key in START or RUN
- David56
Don't be too hard on yourself.David56 wrote: Dave56. The dummy with the cadillac Seville. 2004 Northstar.
I think the PCM is under the air cleaner box in it's own compartment.
I moved this question to your own existing thread. Keeping all your questions and tests performed in one thread helps others follow the flow of your diagnosis and keeps the forums from getting cluttered.
No harm, no foul.
- David56
Yes that's the only place. Box in front nothing in middle works.pole71 wrote:
- David56
Yes power in backseat box. Just pulled ecm never seen a green and white wire.David56 wrote:
