2013 Dodge Dart Limited 1.4l w/ C635 DDCT "Transmission service info help"
  • davehemicharger426
  • davehemicharger426's Avatar Topic Author
1 year 9 months ago - 1 year 9 months ago #78396 by davehemicharger426
C635 DDCT
Hi! Reaching out to the community to see if anyone has any service info pertaining to the overhaul procedures for the valve body assembly on these transmissions?
I have found overhaul info on transmission assembly but nothing on valve body. I am looking for parts breakdown diagram, hydraulic circuit, disassembly and reassembly w/pics- illustrated diagrams, also torque specs for separator plate bolts. Purchased an overhaul kit by Precision International #KP31900H from Buffalo Engine Components but does not come with any instructions. Backstory of this is it threw a P1C99 code, "Gear shift position sensor 1 circuit. " This sensor module lives inside on backside of valve body. Sensor 1 was bad. Sensor 1 is part of an integrated sensor module that to my understanding has 7 sensors total. 4- gear shift actuator sensors, 2- speed sensors for both odd and even transmission shafts and 1- temp sensor. FYI Dodge to my knowledge does not sell just the sensor module they want you to purchase whole valve assembly with reservoir and pump $2500 +, I stumbled across  mlreng.com  they sell new and used sensors, only company I found that does. Any info would be appreciated. Thanks
Last edit: 1 year 9 months ago by davehemicharger426. Reason: edit subject title
