GM 3100, crank no start!
  • cdakan841
  • cdakan841's Avatar Topic Author
8 years 7 months ago #18378 by cdakan841
GM 3100, crank no start! was created by cdakan841
Hello I have a 1997 Chevy lumina, 3100 engine, crank no start, I have checked for spark and have good spark, it will run off of spraying a fuel source in the intake, fuel pressure is good but I have no injection pulse, power to injector but no ground side pulse from computer, I have checked cam and crank sensors, both are Hall effect and I believe both are good, the crank sensor signal wire pulses around 24-30 times per revolution, I don’t have a scope so I’m watching a multimeter as I turn the engine by hand, I also checked the cam signal the same way and it pulses once every 2 revolutions of the crank pulley, I’m about to
call a bad driver on the computer but I wanted to see if anyone had any other ideas before I called it.
8 years 7 months ago #18382 by kostelectronics
Replied by kostelectronics on topic GM 3100, crank no start!
In this case, you Need a Wiring-Diagram to eliminate all possibilities. You should check all input-signals direct at the ECU, the Outputs too. Maybe you have only a broken wire and the ECU doesn't see the cam or crank-signal but you can see it at the sensor directly.
Do you can communicate with the ECU?
  • cdakan841
8 years 7 months ago #18383 by cdakan841
Replied by cdakan841 on topic GM 3100, crank no start!
Yes I checked the cam and crank signals at the ecu, I also checked for the injection pulse at the computer and I don’t have any, I rang out all the wires from the computer to each connector with an ohm meter and they all tested good
8 years 7 months ago #18384 by kostelectronics
So, you have cam/crank signals direct at the Computer and no injection pulse Output, correct?
If all Power/GND Connections at the Computer are fine and no anti-theft System is active, i whould also say the Computer is bad.
But i really hate this to say, my expierience is, that mostly something else is wrong, not the Computer!
  • cdakan841
8 years 7 months ago #18385 by cdakan841
Yes, I will double and triple check everything again tomorrow but that’s what I came up with today, do you know if the computers on these need to be flashed or anything or if I can just pull one from a junkyard and throw in to try?
8 years 7 months ago #18386 by kostelectronics
I can't say 100% but i guess it's not probrammed, because it's an old style System. Let this question answer somebody else :)
But if your Computer is really cooked, you have to find out why. Maybe a coil is bad and fired trough the control-wire back into the Computer and killed it.
8 years 7 months ago #18394 by Tutti57
Replied by Tutti57 on topic Re:GM 3100, crank no start!
If you find the computer is bad there are some services on eBay where you provide Vin and they give you another computer. I didn't need to send a core when I did it on a GM on the past. About a week turnaround. Just have to do key and crank relearn. Takes about 30 min.
  • cdakan841
8 years 7 months ago #18691 by cdakan841
ok Guys just wanted to give you an update to what happened with this and how it got resolved, I did not replace the computer, it ended up being 2 different problems, first problem and original problem was the security system, which I bought a gm vats bypass module from eBay and installed, once installed, and this is where it got screwy, rather than once again testing the computer output for a injector ground pulse I just tried to start the car, it didn’t start so I assumed that it was the same problem, NEVER ASSUME! so after a couple days of beating my head off the wall I re checked for injector pulse and realized I actually had it and I was looking at another problem, that problem ended up being a weak fuel pump, it was running and actually pumping fuel but it wasn’t building enough pressure, so overall I had a security issue and a bad fuel pump threw in the mix which really had me confused for a little bit. Thanks again for all the feedback!!
Time to create page: 0.248 seconds
