2011 Dodge Caravan 3.6L heavy Miss Under load no codes
  • oneilsgarage
  • oneilsgarage's Avatar Topic Author
1 year 9 months ago #77945 by oneilsgarage
have a 2011 dodge caravan come in with code P0302 cylinder #2 misfire , had replaced all coils and plugs before christmas. discovered a lower plenum leak repaired that . now theres no codes still runs rough at idle and when driven it shakes so bad at 60 km/hr you would think it would set a code but it don't. swapped upstream O2s doesn't change a whole lot.
1 year 9 months ago #77946 by Noah
Since there are no codes, do the misfire pids count up on cylinder two while you experience this shaking?
  • oneilsgarage
1 year 9 months ago #77949 by oneilsgarage
no pids in scanner
1 year 9 months ago #77955 by Noah
I don't know what tool you are using, but Chrysler vehicles dont put the misfire data with the rest of the data.
It usually found under functional tests, or system tests under "which cylinder is misfiring"
  • oneilsgarage
1 year 9 months ago #77960 by oneilsgarage
Noah the problem has been resolved thanks for the help.
PS. Never trust a NEW coil
1 year 9 months ago #77962 by Noah
N.E.W.
Never Ever Worked.
Glad you got it, thanks for the update
