2019 Jeep Cherokee, 2.4L P0001 and other communication faults
  • brianmstoltzfus
  • brianmstoltzfus's Avatar Topic Author
1 year 9 months ago #77929 by brianmstoltzfus
Hi, I have a 19 Jeep Cherokee in my shop that very intermittently sets a bunch of communication faults. Most of the modules on CAN C are setting codes when the fault occurs. The list of codes is long enough to fill a page but they are all communication faults and they all set at the same time as far as I know. I drove the car about 10 miles monitoring the CAN C signal at the PCM and this is what it looks like. The fault did not occur during this drive. I am used to seeing CAN signal looking more uniform without the spikes. Does someone know if this looks normal?
1 year 9 months ago #77931 by ferris48
looks good to my eye. yellow hovers around 2.5 and jumps to 3.5, green hovers around 2.5 and drops to 1.5.
catching it in the act and then determining which module is causing it will be the hard part if you can't get it to act up in 10 miles. yikes.
This video may interest you.
1 year 9 months ago #77939 by Lupe
I would disconnect batt for more then 4 hr ,test it, and start over , check alternator , com codes that return .
  • brianmstoltzfus
1 year 9 months ago #77952 by brianmstoltzfus
Helpful video, thanks!
  • brianmstoltzfus
1 year 9 months ago #79244 by brianmstoltzfus
Update: I was able to drive the car enough to create the problem. It only happens briefly, usually after driving while the car is idling. But even then, very intermittent. Here is a can capture when the fault is occurring, after unplugging the ABS from the CAN C star connector, the communication appears normal. I was able to plug it back in, fault returned. Are we pretty safe to put an ABS module in it?
1 year 9 months ago - 1 year 9 months ago #79282 by ferris48
can c stops at abs module and is not a passthrough to other modules, so yes, that abs module is bad
Last edit: 1 year 9 months ago by ferris48.
1 year 9 months ago #79290 by ferris48
beat it with a stick see if you can make it act up on command
1 year 9 months ago #79292 by ferris48
while pinching a loaf and studying that waveform, nice capture by the way, i'm not smart enough to say if it's the module or a connector. The diagram also shows connector XY207A and I don't know where that is
  • brianmstoltzfus
1 year 8 months ago #80007 by brianmstoltzfus
I wish we could have put a module in it and proved a repair. Thanks for the help!
  • brianmstoltzfus
1 year 8 months ago #80008 by brianmstoltzfus
I should have said the customer declined the repair.
1 year 8 months ago #80304 by ferris48
thanks for the update.
in hindsight i think unplugging the abs directly at the abs connector would be more bulletproof evidence and if this is hard to reach, pulling the fuses for the abs may work.
i'd still beat it cause it feels good.
