volvo s80 2.4 bias on o2 sensor
- Inge Jeppesen
- Ford master tech.
- Thank you received: 3
Anybody know if volvo use bias voltage on their o2 signal curcuit? I have 4 volts on b1s1 signal wire.
Also dtc on the sensor for signal fault.
This is a 2000 model if I remember correct.
The heater curcuit is ok drawing about 5 amps in total for both sensors. (If that is normal)
- Thank you received: 1138
- Inge Jeppesen
- Ford master tech.
Do you know what the normal amp reading of a heater should be?
A week ago I would have said no way, but then we had this thread about a 1V bias on a Toyota O2. Weird :blink:
If it's a good ol' zirconia O2, then I'd expect anywhere from 500mA to 1A. Five amps for two sensors seems a bit high to me... Knowing specified heater resistance would help give us a better idea of what these are supposed to be drawing.
- Inge Jeppesen
- Ford master tech.
Inge Jeppesen wrote: I will measure the new one before I install it. It has to be bias voltage. When I measured the downstream it was steady at 0,8 volts. Pulled a vacuumline and it responded like it should.
Works for me! Eager to hear the result on this one, my mind has been getting blown with these wacky O2 bias voltages recently...
Just for fun, I did some quick Ohms law math. *IF* both heaters are full fielded, and of the same resistance, then they'd be drawing 2.5A individually. That works out to an individual resistance of around 5 Ohms. Sounds low to me, but it's a Volvo, so who knows? :lol:
- Inge Jeppesen
- Ford master tech.
Before I discovered "SD" I did not know what bias was at all. When I watch his videos it's like : " ah now you are forgetting something Paul.... and bam... he sais exactly what I was thinking. Amazing.
- Inge Jeppesen
- Ford master tech.
Put new sensor in. Same 3.8 volt steady signal. After 5 starts and stops and the CEL is gone. :woohoo:
Heater resistance old sensor 2.5 ohms. New 1.5 ohms. Same model and make denso original volvo sensor.
Thinking this might be a broadband sensor?
Or is it a magical sensor?
Inge Jeppesen wrote: So.......
Wow :blink: This is an upstream sensor, right? I hadn't even thought about the possibility of a air fuel ratio sensor in a 2000 MY.
I'm happy that the car is happy
- Inge Jeppesen
- Ford master tech.
3.8 volts on signal wire to engine ground.
I never measured signal ground wire since I got the 3.8 result.
Both upstream and downstream look the same. Except for the part number.
This is a strange case. Hope the CEL stays of...
