2015 Silverado 2500HD LML
  • BobRoss1
  • BobRoss1's Avatar Topic Author
1 year 9 months ago #77508 by BobRoss1
2015 Silverado 2500HD LML was created by BobRoss1
Hey guys, does anyone happen to know the typical range of the “Induction System Leak Indication” at idle on a 2015 Chevrolet Silverado 2500HD with LML Duramax? I’m getting a ratio of 0.61:1. Does this mean I’m getting more or less air than what the MAF is reading? The truck is also not building boost like it should. Any help is appreciated.
1 year 9 months ago - 1 year 9 months ago #77759 by Tyler
Replied by Tyler on topic 2015 Silverado 2500HD LML
Hey BobRoss! I got this from a training class I went to several years ago:
Less than .90:1 - Measured airflow too low due to leaks between the MAF and turbo inlet (i.e. unboosted intake) or MAF miscalibration. Can also be caused by a failed turbo, exhaust leaks between the exhaust manifolds and the turbo, or EGR flow (not seating).
More than 1.10:1 - Measured airflow too high due to MAF miscalibration or leaks in the boosted side of the intake. Free- flowing exhaust can also reduce this ratio (increase flow).
There's also PIP4932D which says pretty much the same thing:
This browser does not support PDFs. Please download the PDF to view it: Download PDF
Remember that the ALER/ASLI/ILSI reading is only valid if the EGR valve is closed. Was your reading of .61:1 with the EGR valve closed? If not, that might be part of the problem. Close the EGR and recheck your reading.
Last edit: 1 year 9 months ago by Tyler.
The following user(s) said Thank You: BobRoss1
  • BobRoss1
1 year 9 months ago #77825 by BobRoss1
Replied by BobRoss1 on topic 2015 Silverado 2500HD LML
Thanks for the information! I will command the EGR closed and check the ISLI again. I suspect the leak may be on the unboosted intake like you mentioned because my last used oil analysis showed elevated iron levels. Is there a standard method used to find the leak on the unboosted side? Thanks for the help!
