P0174 only
  • Huckleberry
  • Huckleberry's Avatar Topic Author
8 years 8 months ago - 8 years 8 months ago #17938 by Huckleberry
P0174 only was created by Huckleberry
2001 ford 7700 5.4 p0174 code. Smoke tested, repaired vac lines, saw some smoke coming out out from under mushroom top of egr, i replaced it.Replaced pvc and rubber piece behind the intake for good measure. I cleared the code, drove for about 150 miles, checked for codes again, p0174 was pending. Needed to have it inspected for registration. Took it in, and it passed. Check engine lite came back on after driving bout another 50 miles.
I checked freeze frame data. under load was around 75, idle bout 680, short and long term fuel trims, bank 1, -2 to +5. Bank 2 fuel trims,short term +4 apprx. long term +29. Checked the long term while driving, would be around +19 to+21. Haven't replaced fuel filter, figured if it was it, it would throw the p0171 also.
So can anyone suggest anything else?
OK, just did a smoke test again. Found smoke coming out around the piece that the pvc elbow attaches to behind the throttle body, don't know what it is. Could this be the culprit?
If ignorance is blessed, i got to be happy!!!1
Last edit: 8 years 8 months ago by Huckleberry. Reason: adding more info
8 years 8 months ago #17948 by Ben
Replied by Ben on topic Re:P0174 only
Did you reset the kam? I assume you cleared code and it returned after repairs? What are your maf readings at idle ?
  • Huckleberry
8 years 8 months ago #17952 by Huckleberry
Replied by Huckleberry on topic Re:P0174 only
Yes reset it. Maf reading at idle 0.01 (lb/s) 0.04 @ 2500 rpm's
8 years 8 months ago #17969 by Ben
Ok idle seems a little low next we need to do a wide open throttle run in 1st gear and see what its peak is . Also if you can get load on that same run and b1s1 and b2s1 oxygen sensor make sure they go full rich approx 800mv the whole time your foot is on the floor.
8 years 8 months ago #17970 by Ben
Also I just noticed you had a leak at the pcv elbow did you repair this? Any leaks will cause lean codes.
8 years 8 months ago #17971 by Tutti57
Replied by Tutti57 on topic Re:P0174 only
It looks like something bank specific.
  • Huckleberry
8 years 8 months ago #17976 by Huckleberry
Ok Ben. Flooring it in first gear.
Readings:
Rpm: 4507
Maf: 199.2
short term FT b1: 17.2
long term FT b1: 0.0
short term FT b2: 18.0
long term FT b2: 1.6
02b1s1: 0.925
02b2s1: 0.855
Did a smoke test a couple weeks ago, found a couple leaks.Things i've changed: fuel filter, pcv, egr( had smoke coming out from under the mushroom lookin cap), repaired some vacuum lines, replaced boot on back side of throttle body.
Yesterday did another smoke test, had smoke coming out of the IAC where the lil round piece is on the side of it.
By the way, thanks for your help.
8 years 8 months ago #18040 by Ben
Ok maf is right on oxygen sensors look good and suggest were not lacking fuel, however are short term fuel trims say were lean on both banks at that rpm but are long term hasn't compensated for it yet. What was the freeze frame for the code was it at idle rpm or driving hot or cold? Does this engine have manifold/exhaust leaks?
  • Huckleberry
8 years 7 months ago - 8 years 7 months ago #18544 by Huckleberry
Ok, after further inspection, no change. long fuel trim b2 +29.7. Smoked again, have some smoke coming from back of throttle body still, in the area of the pvc elbow and iac. Can't tell which one is leaking, or even if they are. I have replaced both. Could there be a leak back there from throttle body? Is there a port from intake manifold underneath that area? I've looked and can't tell without removing a some things. I also did the water test there with no results. Also yesterday i had a 442 code pending(evap) UGH!
I just confirmed the iac is leaking when i smoked it. Is it suppose to? It's new.
Last edit: 8 years 7 months ago by Huckleberry.
8 years 7 months ago #18566 by Ben
Where is the iac leaking back to the intake tube or out of the body itself ?
  • cheryl hartkorn
  • cheryl hartkorn's Avatar
8 years 7 months ago #18569 by cheryl hartkorn
Replied by cheryl hartkorn on topic Re:P0174 only
what was the intake air temp reading when you did the w.o.t. test?? i ran the volumentric efficiency test otc has and put 75 degrees and its only coming out to 70% which is low. every class i been to 75 is the minmum they want you to see.
  • Huckleberry
8 years 7 months ago #18571 by Huckleberry
From what i can tell, the body itself, that's why i replaced the last one.
  • Huckleberry
8 years 7 months ago #18572 by Huckleberry
I don't know cheryl. I must of erased the data.
8 years 7 months ago #18619 by Ben
Replied by Ben on topic Re:2004 Jeep GC NO COMM 5V Ref
Roughly what temperature was it in your area at the time of your wide open throttle run ? Does this truck have a exhaust leak (common for studs to break) does this truck have a misfire? May pull the plugs on bank 2 and see what they look like. Does your scan tool do injector pressure drop testing? Does the truck lack power ?
  • Huckleberry
8 years 7 months ago - 8 years 7 months ago #18622 by Huckleberry
Replied by Huckleberry on topic Re:2004 Jeep GC NO COMM 5V Ref
Temp probaly in the 50"s. As for as the exhaust leak,? Can't hear a leak as well as sprayed lil soap and water at the joint. However, the muffler has a small hole in it, cause i notice after starting and letting it idle a lil while, seems to have an abnormal amount of condensation coming out from the exhaust pipe and that small hole. I can feel a slight hiccup in the idle. Doesn't lack power. My scan tool doesn't have the injector testing feature. I'll pull plugs tomorrow. Overall truck runs great, it's just that long term fuel trim is bugging the crap out of me.
  • Huckleberry
8 years 7 months ago - 8 years 7 months ago #18700 by Huckleberry
Replied by Huckleberry on topic updated scan readings
OK changed driver side plugs. Recorded WOT on scan tool. Here's my readings. Outside Temp, about 60
Numbers of DTCs 0
Fuel system 1 statusCL
Fuel System 2 status--
Calculated Load Value(%)23.1
Engine Coolant Temperature(¡£C)96
Short Term Fuel Trim -Bank 1(%)-1.6
Long Term Fuel Trim - Bank 1(%)-14.1
Short Term Fuel Trim -Bank 2(%)-2.3
Long Term Fuel Trim - Bank 2(%)10.9
Engine RPM(rpm) 790
Vehicle Speed Sensor(km/h)0
Ignition Timing Advanece for #1 Cylinder(¡£)13.5
Intake Air Temperature(¡£C)23
Air Flow Rate from Mass Air Flow Sensor(g/s)26.02
Absolute Throttle Position(%)78.4
Location of Oxygen SensorsB1S12--B2S12--
Oxygen Sensor Output Voltage Bank 1-Sensor 1(V)0.720
Short Term Fuel Trim Bank 1-Sensor 1(%)17.2
Oxygen Sensor Output Voltage Bank 1-Sensor 2(V)0.650
Short Term Fuel Trim Bank 1-Sensor 2(%)N/A
Oxygen Sensor Output Voltage Bank 2-Sensor 1(V)0.080
Short Term Fuel Trim Bank 2-Sensor 1(%)17.2
Oxygen Sensor Output Voltage Bank 2-Sensor 2(V)0.630
Short Term Fuel Trim Bank 2-Sensor 2(%)99.2
OBD requirements to which vehicle is designedOBDII
Numbers of DTCs 0
Fuel system 1 statusOL-Drive
Calculated Load Value(%)99.2
Engine Coolant Temperature(¡£C)95
Short Term Fuel Trim -Bank 1(%)17.2
Long Term Fuel Trim - Bank 1(%)0.0
Short Term Fuel Trim -Bank 2(%)17.2
Long Term Fuel Trim - Bank 2(%)0.0
Engine RPM(rpm) 2825
Vehicle Speed Sensor(km/h)36
Ignition Timing Advanece for #1 Cylinder(¡£)9.0
Air Flow Rate from Mass Air Flow Sensor(g/s)128.51
Absolute Throttle Position(%)93.3
Oxygen Sensor Output Voltage Bank 1-Sensor 1(V)0.860
Oxygen Sensor Output Voltage Bank 1-Sensor 2(V)0.845
Oxygen Sensor Output Voltage Bank 2-Sensor 1(V)0.785
Oxygen Sensor Output Voltage Bank 2-Sensor 2(V)0.810
Numbers of DTCs 0
Calculated Load Value(%)100.0
Short Term Fuel Trim -Bank 2(%)19.5
Engine RPM(rpm) 4550
Vehicle Speed Sensor(km/h)62
Intake Air Temperature(¡£C)21
Air Flow Rate from Mass Air Flow Sensor(g/s)194.46
Oxygen Sensor Output Voltage Bank 1-Sensor 1(V)0.870
Oxygen Sensor Output Voltage Bank 1-Sensor 2(V)0.880
Oxygen Sensor Output Voltage Bank 2-Sensor 1(V)0.845
Oxygen Sensor Output Voltage Bank 2-Sensor 2(V)0.885
Numbers of DTCs 0
Calculated Load Value(%)20.8
Short Term Fuel Trim -Bank 1(%)-13.3
Long Term Fuel Trim - Bank 1(%)-10.9
Short Term Fuel Trim -Bank 2(%)-10.2
Long Term Fuel Trim - Bank 2(%)24.2
Engine RPM(rpm) 852
Vehicle Speed Sensor(km/h)45
Ignition Timing Advanece for #1 Cylinder(¡£)15.5
Air Flow Rate from Mass Air Flow Sensor(g/s)6.64
Absolute Throttle Position(%)20.0
Oxygen Sensor Output Voltage Bank 1-Sensor 1(V)0.095
Short Term Fuel Trim Bank 1-Sensor 1(%)-13.3
Oxygen Sensor Output Voltage Bank 1-Sensor 2(V)0.865
Oxygen Sensor Output Voltage Bank 2-Sensor 1(V)0.100
Short Term Fuel Trim Bank 2-Sensor 1(%)-4.7
Oxygen Sensor Output Voltage Bank 2-Sensor 2(V)0.895
Numbers of DTCs 0
Calculated Load Value(%)24.3
Short Term Fuel Trim -Bank 1(%)-15.6
Long Term Fuel Trim - Bank 1(%)-15.6
Short Term Fuel Trim -Bank 2(%)-11.7
Long Term Fuel Trim - Bank 2(%)25.0
Engine RPM(rpm) 620
Vehicle Speed Sensor(km/h)20
Ignition Timing Advanece for #1 Cylinder(¡£)17.5
Air Flow Rate from Mass Air Flow Sensor(g/s)6.58
Oxygen Sensor Output Voltage Bank 1-Sensor 1(V)0.075
Short Term Fuel Trim Bank 1-Sensor 1(%)-11.7
Oxygen Sensor Output Voltage Bank 1-Sensor 2(V)0.855
Oxygen Sensor Output Voltage Bank 2-Sensor 1(V)0.525
Short Term Fuel Trim Bank 2-Sensor 1(%)-10.9
Numbers of DTCs 0
Calculated Load Value(%)25.5
Short Term Fuel Trim -Bank 1(%)-8.6
Long Term Fuel Trim - Bank 1(%)-12.5
Short Term Fuel Trim -Bank 2(%)-3.9
Long Term Fuel Trim - Bank 2(%)21.1
Engine RPM(rpm) 720
Vehicle Speed Sensor(km/h)11
Ignition Timing Advanece for #1 Cylinder(¡£)18.0
Air Flow Rate from Mass Air Flow Sensor(g/s)6.69
Oxygen Sensor Output Voltage Bank 1-Sensor 1(V)0.080
Short Term Fuel Trim Bank 1-Sensor 1(%)-5.5
Oxygen Sensor Output Voltage Bank 2-Sensor 1(V)0.105
Short Term Fuel Trim Bank 2-Sensor 1(%)0.0
Oxygen Sensor Output Voltage Bank 2-Sensor 2(V)0.875
Numbers of DTCs 0
Calculated Load Value(%)23.9
Short Term Fuel Trim -Bank 1(%)-6.3
Long Term Fuel Trim - Bank 1(%)-14.8
Short Term Fuel Trim -Bank 2(%)-6.3
Long Term Fuel Trim - Bank 2(%)23.4
Engine RPM(rpm) 646
Air Flow Rate from Mass Air Flow Sensor(g/s)6.14
Oxygen Sensor Output Voltage Bank 1-Sensor 1(V)0.045
Short Term Fuel Trim Bank 1-Sensor 1(%)-3.1
Oxygen Sensor Output Voltage Bank 1-Sensor 2(V)0.840
Oxygen Sensor Output Voltage Bank 2-Sensor 1(V)0.120
Short Term Fuel Trim Bank 2-Sensor 1(%)2.3
Oxygen Sensor Output Voltage Bank 2-Sensor 2(V)0.870
Numbers of DTCs 0
Short Term Fuel Trim -Bank 1(%)-0.8
Short Term Fuel Trim -Bank 2(%)-3.1
Long Term Fuel Trim - Bank 2(%)22.7
Engine RPM(rpm) 738
Ignition Timing Advanece for #1 Cylinder(¡£)12.0
Air Flow Rate from Mass Air Flow Sensor(g/s)6.47
Oxygen Sensor Output Voltage Bank 1-Sensor 1(V)0.055
Short Term Fuel Trim Bank 1-Sensor 1(%)2.3
Oxygen Sensor Output Voltage Bank 1-Sensor 2(V)0.830
Oxygen Sensor Output Voltage Bank 2-Sensor 1(V)0.060
Short Term Fuel Trim Bank 2-Sensor 1(%)4.7
Oxygen Sensor Output Voltage Bank 2-Sensor 2(V)0.860
Numbers of DTCs 0
Calculated Load Value(%)21.6
Engine Coolant Temperature(¡£C)97
Short Term Fuel Trim -Bank 1(%)1.6
Long Term Fuel Trim - Bank 1(%)-13.3
Short Term Fuel Trim -Bank 2(%)3.1
Long Term Fuel Trim - Bank 2(%)26.6
Engine RPM(rpm) 755
Air Flow Rate from Mass Air Flow Sensor(g/s)5.75
Short Term Fuel Trim Bank 1-Sensor 1(%)-1.6
Oxygen Sensor Output Voltage Bank 2-Sensor 1(V)0.625
Oxygen Sensor Output Voltage Bank 2-Sensor 2(V)0.855
Numbers of DTCs 0
Calculated Load Value(%)22.7
Short Term Fuel Trim -Bank 1(%)0.8
Engine RPM(rpm) 729
Ignition Timing Advanece for #1 Cylinder(¡£)14.5
Intake Air Temperature(¡£C)22
Air Flow Rate from Mass Air Flow Sensor(g/s)5.98
Oxygen Sensor Output Voltage Bank 1-Sensor 1(V)0.745
Short Term Fuel Trim Bank 1-Sensor 1(%)-3.9
Oxygen Sensor Output Voltage Bank 1-Sensor 2(V)0.825
Oxygen Sensor Output Voltage Bank 2-Sensor 1(V)0.655
Short Term Fuel Trim Bank 2-Sensor 1(%)-1.6
Oxygen Sensor Output Voltage Bank 2-Sensor 2(V)0.850
Numbers of DTCs 0
Calculated Load Value(%)22.4
Long Term Fuel Trim - Bank 1(%)-16.4
Short Term Fuel Trim -Bank 2(%)-0.8
Engine RPM(rpm) 678
Air Flow Rate from Mass Air Flow Sensor(g/s)5.92
Oxygen Sensor Output Voltage Bank 1-Sensor 1(V)0.535
Oxygen Sensor Output Voltage Bank 1-Sensor 2(V)0.820
Short Term Fuel Trim Bank 2-Sensor 1(%)-0.8
Oxygen Sensor Output Voltage Bank 2-Sensor 2(V)0.845
Numbers of DTCs 0
Calculated Load Value(%)22.0
Short Term Fuel Trim -Bank 1(%)-5.5
Long Term Fuel Trim - Bank 1(%)-17.2
Short Term Fuel Trim -Bank 2(%)-4.7
Engine RPM(rpm) 696
Air Flow Rate from Mass Air Flow Sensor(g/s)5.86
Short Term Fuel Trim Bank 1-Sensor 1(%)0.8
Oxygen Sensor Output Voltage Bank 1-Sensor 2(V)0.815
Short Term Fuel Trim Bank 2-Sensor 1(%)1.6
8 years 7 months ago #18807 by Tutti57
Do you have a way to graph the recorded day with your scan tool? It is a lot easier to read that way.
  • Huckleberry
8 years 7 months ago #18893 by Huckleberry
No, but got my hands on a stethoscope, and think i found the problem. Air leak back side of throttle body. When i ran a smoke test , had smoke coming from that area, replaced pvc elbow and iac and still had smoke coming out. Ran the scope along the seam of throttle body and intake, and could hear what sounds like air.Replacing gasket today.
Time to create page: 0.386 seconds
