2005 nissan maxima 3.5 negative intake vacuum
  • Willsauto
  • Willsauto's Avatar Topic Author
10 years 1 month ago #1917 by Willsauto
hello everyone from chicago, new at this forum for paul danner, i have a 2005 nissan maxima with negative vacuum pressure in the intake and i don t remember if that exactly means a restricted catalytic convertor. also vehicle has no power while driving and no accel, feels like a clogged cat, found stored code with no service engine light on P0726 & C1130, both are telling me to check cam sensors and scoping them, which was done all ready
10 years 1 month ago #1944 by Tyler
Hey there, welcome to the forums!
Could you clarify for me what you mean by negative vacuum pressure? Are you referring to low manifold vacuum at idle?
You may be on the right track with a clogged cat. How does the vacuum gauge behave during a WOT snap in park?
The codes you listed and the symptoms you describe remind me of a TSB I saw once regarding erratic ABS wheel speed sensors, specifically the rears. The ABS freaks out and commands a fuel cut. Do the traction control lights come on when the engine falls on its face?
