2008 hyundai sonata battery light on (not charging)
- Oscar442
8 years 8 months ago #17785
by Oscar442
2008 hyundai sonata battery light on (not charging) was created by Oscar442
HELLO im working on a 2008 sonata it has new alternator and battery but keeps loosing charge alternator is not exciting or coming on apparently the computer is not controlling the regulator i know the regulator is internal but dont have a clear way to test it looking for some help please and thank you
- Oscar442
8 years 8 months ago #17843
by Oscar442
Replied by Oscar442 on topic 2008 hyundai sonata battery light on (not charging)
thank you so much for your reply but i dont see a white wire i only have green and yellow
8 years 8 months ago #17846
Replied by Andy.MacFadyen on topic 2008 hyundai sonata battery light on (not charging)
From what I can see although the DRL control unit is wired to the circuit it doesn't control alternator , the alternator warning light circuit is an input to the DRL control unit so the DRL are only illuminated when the alternator is charging.
The alternator is connected to the ECU but I suspect this is duty cycle signal from the alternator to the ecu rather than the ECU controlling the alternator.
- rockp2
- Thank you received: 40
8 years 8 months ago #17853
by rockp2
Replied by rockp2 on topic 2008 hyundai sonata battery light on (not charging)
Is it possible the ALT FUSIBLE LINK 150A is blown? Maybe the customer hooked up battery cables backwards getting a jump with the old battery?
- Oscar442
8 years 8 months ago #18049
by Oscar442
i wish but its good but i do need to check the discharging circuit like someone mentioned earlier
- Oscar442
8 years 8 months ago #18050
by Oscar442
who do you use for diagrams?
Time to create page: 0.254 seconds
