Subaru 2.5
- cyrus.nk
10 years 1 month ago #1839
by cyrus.nk
Subaru 2.5 was created by cyrus.nk
Can p0503 vss erratic code make the car stall at high kph wen the brakes are applied and cousing hesitition from 600 to 1200 idle.air fuel learning 7 at idle,0 at 4000 rpm and 8 at 7000 rpm.
- Caritech
- Thank you received: 10
10 years 1 month ago #1849
by Caritech
Replied by Caritech on topic Subaru 2.5
I say if you are having issues and that's the code you are getting follow that path. Establish your necessary testing procedures and gain your evidence. Google helps sometimes.
10 years 1 month ago #1855
Replied by Tyler on topic Subaru 2.5
I personally have never known a VSS code to cause stalling on a Subi. I'm with Caritech, though, you may end up following that code and end up finding the actual problem along the way.
Does the VSS signal drop out on scan data during the stall?
- cyrus.nk
10 years 1 month ago #1860
by cyrus.nk
Replied by cyrus.nk on topic Subaru 2.5
Once u turn on position
- cyrus.nk
10 years 1 month ago #1878
by cyrus.nk
Replied by cyrus.nk on topic Subaru 2.5 sg5
Any one know location of vehicle speend sensor?
10 years 1 month ago #1883
The VSS drops out once the key is turned on? Not trying to be a jerk, just clarifying
Not off the top of my head. What's your Y/M/M? I can dig a little deeper knowing that.
cyrus.nk wrote: Once u turn on position
- cyrus.nk
10 years 1 month ago #1921
by cyrus.nk
2006 SG5 subaru.if u dnt know it just Google sg5 subaru.but I think the problem is wss because vehcle speed is monitord from there.after deep checking i got wheel speed sonsor for RH
Time to create page: 0.366 seconds
