Crank no start kind of. SVT Focus
8 years 8 months ago #17109 by Jbond
Crank no start kind of. SVT Focus was created by Jbond
2002 Ford Focus SVT
P0172 code
Symptoms surfaced after car overheated.
Car cranks normally. After 3 seconds of cranking it hesitates to start but does not. After removing the spark plugs to remove unfired fuel it starts and runs normal. Once it reaches operating temperature the car can be shut on and off without problems. When the car cools down it will not start again. Repeating the process.
Compression test done, results ok
Parts checked/replaced
MAF
Spark plugs
Spark plugs wires
Cool temperature sensor
Fuel rail pressure sensor
Coil pack
8 years 8 months ago #17110 by Lustfulvengance
Replied by Lustfulvengance on topic Crank no start kind of. SVT Focus
First thing that comes to mind is coolant getting into cylinders (overheated, warped head, blown headgasket, ect)
2nd would be a valve sealing issue from the overheating
8 years 8 months ago #17112 by Tutti57
Replied by Tutti57 on topic Re:Crank no start kind of. SVT Focus
I might try an injector balance test to see if one is leaking, in case there isn't a real link to the overheating. Was that issue addressed and what caused it?
8 years 8 months ago #17126 by juergen.scholl
Replied by juergen.scholl on topic Re:Crank no start kind of. SVT Focus
Apart from replacing parts did you confirm they're operating correctly?
Do you loose coolant? Can you pressure test the cooling system?
Does the fuel pressure hold after engine shutdown no injector leaking there?
