[FIXED] Vent solenoid control circuit
  • randy.martin
  • randy.martin's Avatar Topic Author
8 years 9 months ago - 8 years 8 months ago #17046 by randy.martin
[FIXED] Vent solenoid control circuit was created by randy.martin
07 GMC Yukon XL 5.3L
EVAP VENT SOLENOID CONTROL CIRCUIT
Checked the wires at the solenoid underneath the car. Good power. Bi-directionally turned it on and off with the scan tool while watching the voltage on the control wire. (Same test was done plugged and unplugged) when not commanded on reads approx. 450mv and commanded on reads ground voltage at 20mv. Reads the same at the computer. Is this normal operation or is this looking like a bad driver? Need help fast if possible. Thanks guys
Last edit: 8 years 8 months ago by Tyler.
  • randy.martin
8 years 9 months ago #17048 by randy.martin
Replied by randy.martin on topic Vent solenoid control circuit
Disregard. Found the reference material. Checked the circuit. Open in the solenoid
  • randy.martin
8 years 9 months ago #17049 by randy.martin
Replied by randy.martin on topic Vent solenoid control circuit. Fixed
Fixed
8 years 9 months ago #17056 by Noah
Replied by Noah on topic Vent solenoid control circuit. Fixed
Thanks for updating this even though you didn't get any responses.
It may help someone in the future searching the forum.
The following user(s) said Thank You: Gjauto
8 years 9 months ago #17072 by Gjauto
Replied by Gjauto on topic Vent solenoid control circuit
good fix. When you checked the control circuit when it was commanded off, you shouldve seen B+ through the solenoid winding.
