Ford Ranger 2010 multi DTC code
  • Anhpha
  • Anhpha's Avatar Topic Author
8 years 9 months ago #17013 by Anhpha
Ford Ranger 2010 multi DTC code was created by Anhpha
Dear Paul,
Please help to explain for this case as follows:
- Car : Ford Ranger 2010 engine 2.5L
- Fuel : Diesel
- Symptom : Engine run with RPM not more than 2500rpm
- DTC code including:
Thank you !
  • graywave
  • graywave's Avatar
8 years 9 months ago #17016 by graywave
Replied by graywave on topic Ford Ranger 2010 multi DTC code
I would check your engine harness for rodent damage.
I took a quick look at a wiring diagram and some of those share power from fuses so I would check to make sure all your fuses are good as well.
Let us know what you find
  • chief eaglebear
  • chief eaglebear's Avatar
8 years 8 months ago #17410 by chief eaglebear
Replied by chief eaglebear on topic Ford Ranger 2010 multi DTC code
a qwik tip on those circuit high codes one way of checking the wiring is use a test light bring them low and that should narrow it down to the sensor itself
  • chief eaglebear
8 years 8 months ago - 8 years 8 months ago #17411 by chief eaglebear
the po0098 is an air temp sensor which I think is a critical input if your ecm doesn't know what the real temp is I believe it will limp home and use substituted values and also may prevent engine from going above 3000 rpm or something like that
Last edit: 8 years 8 months ago by chief eaglebear.
