Crankshaft variation relearn
- autojoe
- Thank you received: 7
- arbez
- Thank you received: 53
- autojoe
- arbez
Year, Make, Model & Engine Size. Please.
- autojoe
- arbez
autojoe wrote: 2008 Buick Lucerne 3.8
Yea.....
GM you should have to do a relearn. I would expect random misfire codes, not really stalling after 10 minutes.
Check engine light on? Any codes?
- autojoe
- arbez
- autojoe
- arbez
- Gjauto
- Thank you received: 15
You might also check misfire counters on scan tool see if any cylinders report active misfires. If the engine runs smooth, and you do not feel misfires, try using injector disable on scanner and see if the engine responds to each cylinder. Common problem solved by relearn. Good luck!
- Tutti57
- Thank you received: 254
- graywave
- Thank you received: 80
- graywave
Crankshaft Position System Variation Learn
Important: The Crankshaft Position (CKP) system variation learn procedure is also required when the following service procedures have been performed, regardless of whether DTC P0315 is set:
* An engine replacement
* A control module replacement
* A crankshaft balancer replacement
* A crankshaft replacement
* A CKP sensor replacement
* Any engine repairs which disturb the crankshaft to CKP sensor relationship.
Important: The control module monitors certain component signals to determine if all the conditions are met to continue with the CKP System Variation Learn Procedure. The scan tool only displays the condition that inhibits the procedure. The scan tool displays the signals of the following components:
* CKP sensors activity-If there is a CKP sensor condition, Refer to the applicable DTC that set.
* Camshaft position (CMP) signal activity-If there is a CMP signal condition, Refer to the applicable DTC that set.
* Engine coolant temperature (ECT)-If the engine coolant temperature is not warm enough, idle the engine until the engine coolant temperature reaches the correct temperature.
1. Install a scan tool.
2. Monitor the powertrain control module (PCM) for DTCs with a scan tool. If other DTCs are set, except DTC P0315, Refer to Diagnostic Trouble Code (DTC) List - Vehicle (See: A L L Diagnostic Trouble Codes ( DTC ) > Diagnostic Trouble Code Descriptions) for the applicable DTC that set.
3. With a scan tool, select the CKP System Variation Learn Procedure and perform the following:
1. Block drive wheels.
2. Set parking brake.
3. DO NOT apply brake pedal.
4. Cycle ignition from OFF to ON.
5. Apply and hold brake pedal for the duration of the procedure.
6. Start and idle engine.
7. Turn the air conditioning (A/C) OFF.
8. The vehicle must remain in Park or Neutral.
Important: While the learn procedure is in progress, release the throttle immediately when the engine starts to decelerate. The engine control is returned to the operator and the engine responds to throttle position after the learn procedure is complete.
9. Accelerate to wide open throttle (WOT) and release when the fuel cut-off occurs.
4. The scan tool displays Learn Status: Learned this Ignition. If the scan tool indicates that DTC P0315 ran and passed, the CKP variation learn procedure is complete. If the scan tool indicates DTC P0315 failed or did not run, or another DTC is present, Refer to Diagnostic Trouble Code (DTC) List - Vehicle (See: A L L Diagnostic Trouble Codes ( DTC ) > Diagnostic Trouble Code Descriptions) and perform the appropriate diagnostic procedure.
5. Turn OFF the ignition for 30 seconds after the learn procedure is completed successfully in order to store the CKP system variation values in the PCM memory.
- Golliher
I have a 2007 GMC 6L v8 vortec (in an RV)
- autojoe
thinkdiag by thinkcar
Bluetooth that runs on your smartphone
Runs like 100 dollars
Look at manufacturers software when purchase you might get all of them for one year free then have to pay for individual ones then not sure has bi directional controls and special functions
You could contact them on web site and ask them. I seen good reviews
I have pricey snap on versus edge. Wanted to share this with you let me know how you think
- hodged
- ian.evesham
