Delay in rpm to return to idle
- naros812000
8 years 9 months ago #16838
by naros812000
Delay in rpm to return to idle was created by naros812000
Dears,
I have been diagnosing Hyundai Tucson 2009 2.0 DOHC. The issue with this car is when at idle I press the gas pedal to increase rpm to around 3000rpm, when I remove my foot on it, the rpm drops down quickly to 2000 rpm and here it stuck for 3 to 5 second then it begins to return to Idle rpm.
I suspect the Idle air controller valve. I cleaned it and nothing changed.
No DTC available on this car.
Thanks for sharing your information
Is this bad coil?
Thank you
Is this bad coil?
Thank you
- arbez
- Thank you received: 53
8 years 9 months ago #16840
by arbez
Replied by arbez on topic Delay in rpm to return to idle
Does it do this while driving? Is it the same cold & warm?
It is probably not a bad coil
I would look at scan tool data for the APP & the TPS. See of the agree. Check if the desired idle & actual idle speeds agree. Look at command for the IAC. Is the TW sensor reading properly? I would think that something is out of wack & will jump out at you. Maybe you could post scan tool data of when it is acting up & when it is normal.
- Can Bus
- Thank you received: 2
8 years 9 months ago #16841
by Can Bus
There Is No Such Thing As A Stupid Question, If It's Sincere. Better To Ask And Risk Appearing Stupid Than To Continue On Your Own Ignorant Way And Make A Stupid Mistake. Author Confidential/Unknown
Replied by Can Bus on topic Delay in rpm to return to idle
Have you looked inside the throttle body to see if it is gummed up and/ dirty? Is this a cable or electronic throttle body? What are your fuel trims?
8 years 9 months ago #16844
Replied by Andy.MacFadyen on topic Delay in rpm to return to idle
I know it is basic bit a vacuum leak also has to be checked for.
- Can Bus
8 years 9 months ago #16850
by Can Bus
agreed. Looking at fuel trims is something to check into at both cold and warm engine
- naros812000
8 years 9 months ago #16987
by naros812000
Replied by naros812000 on topic Delay in rpm to return to idle
Thank you all,
It was a bad IAC valve. After replacing it. It is working like a charm.
Time to create page: 0.266 seconds
