2001 mustang gt
- Rickyb1982
8 years 9 months ago #16753
by Rickyb1982
2001 mustang gt was created by Rickyb1982
I have a 2001 mustang gt and it will crank but won't start!! The theft light blinks rapidly with key in the on position and while I'm cranking it !! Also there are dashes on the odometer meaning I'm getting no communication from the pcm !! Any recommendations?
- Can Bus
- Thank you received: 2
8 years 9 months ago #16764
by Can Bus
There Is No Such Thing As A Stupid Question, If It's Sincere. Better To Ask And Risk Appearing Stupid Than To Continue On Your Own Ignorant Way And Make A Stupid Mistake. Author Confidential/Unknown
Replied by Can Bus on topic 2001 mustang gt
With the key light flashing it sounds like a key fob issue. You can connect a scanner and see what codes are present. Go into the immobilizer menu and it should tell you if your key is being read. Also, Try a different key. You will need 2 good keys to reprogram.
8 years 9 months ago #16773
Replied by Tyler on topic 2001 mustang gt
I was thinking that the odometer screams communication issue, and the anti-theft light is a reflection of that.
Since you can't talk to the PCM, I'd start with powers and grounds at the PCM itself. Before you go there, you can start with B+ at pin 16 of the DLC, and ground at pins 4 and 5.
Load the grounds with a bulb or the like. No ohm meter. I recall Ford using stupid little single pin ground connectors near the battery, and they like to corrode or unplug themselves due to lack of tension.
- Rickyb1982
8 years 9 months ago #16827
by Rickyb1982
Replied by Rickyb1982 on topic 2001 mustang gt
I tried checking a few pins on the pcm harness with a test light and got nothing
- Rickyb1982
8 years 9 months ago #16828
by Rickyb1982
I tried both of my keys and neither of them work
- arbez
- Thank you received: 53
8 years 9 months ago - 8 years 9 months ago #16837
by arbez
I would be very careful poking around your computer with a test light.
Do you have power & both grounds at the DLC? pinoutguide.com/CarElectronics/car_obd2_pinout.shtml
If the DLC is OK, here are some wiring diagrams to help check at the computer:
www.revbase.com/BBBMotor/Wd/DownloadPdf?id=28635
www.revbase.com/BBBMotor/Wd/DownloadPdf?id=28636
Check all powers & grounds & get back to us. Don't use a test light.
Replied by arbez on topic 2001 mustang gt
Rickyb1982 wrote: I tried checking a few pins on the pcm harness with a test light and got nothing
Last edit: 8 years 9 months ago by arbez. Reason: Link didn't work
- Rickyb1982
8 years 9 months ago #16845
by Rickyb1982
What is the best way to check the grounds ? I've never messed with any of this before
- arbez
8 years 9 months ago - 8 years 9 months ago #16847
by arbez
Did you check the DLC, powers & grounds? Check that first. Trying to see if your no communication issue is caused by a fuse or something. Pin 16 should be battery positive. Pins 4 & 5 should be ground. If power & grounds are OK at the DLC, then move on to the computer.
I'm worried that you could fry the computer by testing with the test light. Check the power leads with a DVOM. OK to check grounds with the test light. Unplug the computer & hook the test light up to battery positive. Light should light when the test light touches a ground connection.
Record your readings & let us know. If powers & grounds are OK, we will have to check outputs from the computer.
Rickyb1982 wrote: What is the best way to check the grounds ? I've never messed with any of this before
Last edit: 8 years 9 months ago by arbez. Reason: Spelling issues
