P129d 2014 corvette stingray
  • johnfry
  • johnfry's Avatar Topic Author
8 years 9 months ago #16669 by johnfry
P129d 2014 corvette stingray was created by johnfry
Hey guys this is the problem. I work at a used car dealership and they have a 2014 corvette stingray they told me the check engine was on so I check the car and it’s not on but there is a p129d code . I tried to clear this but it won’t clear . I haven’t driven this car because it’s sitting on the showroom floor . I checked fuses Ect . Now they want me to see if this module got unplugged well haven’t done any of this kind of work before and I can’t find any info on where this is located or even if I’m chasing a problem that’s even related to this file pump driver module. Help I need a direction on how to handle this beast . I know you all might need more information . I need a direction on this. Thanks
8 years 9 months ago #16673 by arbez
Replied by arbez on topic P129d 2014 corvette stingray
You didn't say what engine you have, so I picked the 6.2
This code is for the Fuel Pump Driver Module - low voltage
I'm going to assume that this car runs. The car wouldn't run with this module unplugged.
This code sets when the FPDM detects less than 6V from the ignition switch
Here is a wiring diagrams:
www.revbase.com/BBBMotor/Wd/DownloadPdf?id=1049802
Looks like you need to check the voltage at the VT/L-GN (violet / light green) wire on the FPDM. This wire gets voltage from the main relay
Check the voltage & let us know
The following user(s) said Thank You: Tyler, johnfry
8 years 9 months ago #16674 by arbez
There is also a 2nd ignition input on the FPDM. Also check voltage on the VT/YE (violet/yellow) wire. Let us know.
The following user(s) said Thank You: johnfry
  • johnfry
8 years 9 months ago #16679 by johnfry
Replied by johnfry on topic P129d 2014 corvette stingray
where is this module located on this car ?
  • johnfry
8 years 9 months ago #16680 by johnfry
Thank you for your information. Yes it’s a 6.2 I will check these voltage on the wires as soon as I can . I’m a brake technician who is trying to expand my abilities to the dealership I work for I’ve been here 9 years and before that I had my own shop ( tires and brakes and some diagnostic work ) but I have been out of the loop 9 years just bought a used verus I’m tired of being a parts changer. Thank you all for your knowledge and help.
8 years 9 months ago #16737 by Tyler
Replied by Tyler on topic P129d 2014 corvette stingray
Looking forward to seeing where this one goes. :cheer: For more info, SMA did a video on this code:
  • cheryl hartkorn
  • cheryl hartkorn's Avatar
8 years 9 months ago #16738 by cheryl hartkorn
Replied by cheryl hartkorn on topic P129d 2014 corvette stingray
Eric has a good channel! real live world work...
8 years 9 months ago #16739 by Tyler
Totally, love his videos. I stole his test light + Vise-Grip idea and made my own. :lol:
8 years 9 months ago #16744 by arbez
johnfry wrote: where is this module located on this car ?
Alldata says its in the rear compartment (trunk?), under the carpet, under an access cover. I hope that helps. Here is what it looks like:
www.amazon.com/ACDelco-23184800-Original...ontrol/dp/B010GKX7V2
Should be an easy diagnosis.
  • johnfry
8 years 9 months ago #16816 by johnfry
Yes this is actually the first video I have seen on this code . I don’t want to sound stupid but any idea where this module is located on this 14 corvette stingray 6.2?
  • johnfry
8 years 9 months ago #16818 by johnfry
Thanks I’ll look in the trunk tomorrow when I get to work and update you on the voltage I come up with.
8 years 9 months ago - 8 years 9 months ago #16821 by arbez
Check all the powers & grounds. Should be an easy diagnosis
Last edit: 8 years 9 months ago by arbez.
