Electrikal problem on an Audi RS6 4B B-Turbo
- Themis
8 years 9 months ago #16604
by Themis
Electrikal problem on an Audi RS6 4B B-Turbo was created by Themis
Hi There, I will first write the Story of the car.
Customer came for an Automatik Transmittion rebuild. to take out the Tranny i needed to take out the Engine too.
After the rebuild i put everything back together. During the Work i discoverd a few broken wires on the wiring harness. I fix them.
I test drove the car 1 hour before the customer came and everything worked fine.
I put the car car on Lift to install some Plastic Parts and since then car didnt start again.
Im searching 2 Weeks now to find the Problem and im really done! So i need your Help.
The problem is that the Engine has almost 5Volts! When i took the Battery cable out of the Alternator the Engine has 0,70Volts.
The Alternator is New.
I checked the starter and is working, but when i crank the Engine (sometimes) i hear the solenoid of the starter cliking but the starter wont move.
The customer sow the Problem himself. We both checked the Wiring Harness and found some more broken cables. I fix them all but i cannot find from where the engine takes Voltage. Fuses Relays and so on are many times duble checked.
the small wire of the Alternator and the Starter are together on one plug and are ending in a fuse and one relay, those are good.
I cannot explain more the problem and sorry for my english but i need Help
thanks in advance
Themis
thanks in advance
Themis
- Tutti57
- Thank you received: 254
8 years 9 months ago #16641
by Tutti57
Replied by Tutti57 on topic Electrikal problem on an Audi RS6 4B B-Turbo
Did you do a voltage drop test at the starter to see if it's getting enough power to turn?
When you say the engine has 5v, what do you mean by that? Where is that measurement taken from?
8 years 9 months ago #16652
Make sure the engine to battery ground cable is good.
Replied by Chad on topic Electrikal problem on an Audi RS6 4B B-Turbo
Themis wrote: The problem is that the Engine has almost 5Volts!
- Themis
8 years 9 months ago #16676
by Themis
Replied by Themis on topic Electrikal problem on an Audi RS6 4B B-Turbo
The problem was indeed the main ground cable. Corrosion every where:(
I put a new one and the engine started.
What confused me was that i had Voltage on the Engine it self(Multimeter,ground on the car and positive on the engine Block)and when i was unpluging the Control cable from the alternator the Voltage was dropping to less than 1V.
With my knowledge i couldnt expain it to me!
Thank you very much for your answers !!!
8 years 9 months ago #16678
This voltage was coming from everything that uses the engine block for a ground. It was all "trying" to get back to the battery.
Themis wrote: What confused me was that i had Voltage on the Engine it self(Multimeter,ground on the car and positive on the engine Block)
Time to create page: 0.261 seconds
