P0206
- VJ
- VJ
- Thank you received: 1138
Is the injector with high resistance on cylinder 6?
Your issue reminds of this one:
- VJ
- VJ
- arbez
- Thank you received: 53
Noid light will show power, ground & control. If you switched the injector to another cylinder & the problem stayed with the original cylinder, your injector isn't the issue.
- VJ
VJ wrote: could I just use a mood light to test the injector signal and see if there is a wiring issue? My injectors are easy to access.
Yes.
- VJ
- arbez
So all your injectors should be within the range of 13.3 ohms to 15.7 ohms @ 68* F
17 Ohms is a little too far out of spec's & I would be very concerned about that injector
Now you say that you switched the injector to a different cylinder & the misfire is now on that cylinder - Strike 2 for that injector
There is no adjustment for the injectors, so the people that installed the new injector had nothing to "dial in"
The noid light is a good way to test the computer driver & wiring - compare the suspected bad cylinder with a known good cylinder - The light flashes should look the same
If you are still skeptical about the new injector being bad, switch it to another cylinder & see where the misfire lands
You are contradicting your previous statement that the misfire did not move, so it's hard to help until we get some more information
Swap that injector to a different cylinder (not one of the previous cylinders) & let us know what happens
- Can Bus
- Thank you received: 2
There Is No Such Thing As A Stupid Question, If It's Sincere. Better To Ask And Risk Appearing Stupid Than To Continue On Your Own Ignorant Way And Make A Stupid Mistake. Author Confidential/Unknown
- Can Bus
I agree with arbez. The noid light will let you know if the power and control are present. If not, then you need a schematic and start tracing wires. Dont panick but i have seen injector control drivers go bad in the pcm for only one injector, especially on a cadillac.
- VJ
- VJ
- VJ
- VJ
- arbez
Unplugging the injector, with no change just says that cylinder isn't contributing. Doesn't necessarily indicate that the injector, or wiring is the issue. If that ignition coil was bad, unplugging the injector would not make any difference. The same if that cylinder had bad compression.
Do you have a noid light, or at least a test light? Any light bulb (12v) that you can use to jump the injector terminals will work. Light should flash with engine cranking or running. Compare it to a good cylinder & let us know.
- VJ
- arbez
- VJ
