Cheverolet Optra 1.6L engine 2008
- naros812000
8 years 9 months ago #16435
by naros812000
Cheverolet Optra 1.6L engine 2008 was created by naros812000
Dears,
I am diagnosing a cheverolet Optra (Lacetti) 2008 1.6L engine. The car doesnt have any code. The problem with the car is sometimes the engine stalls when idling and when starting again, the car denies to start unless the accelerator pedal is pressed then it starts.
Briefly, the car doesnt start and it only cranks unless the pedal is pressed.
Any suggestion?
Thank you
Any suggestion?
Thank you
- derekoliveira
8 years 9 months ago #16466
by derekoliveira
Replied by derekoliveira on topic Cheverolet Optra 1.6L engine 2008
IAC valve is closed or throttle body needs to be cleaned!!!
Look like the engine at idle has lack of air!?
- naros812000
8 years 9 months ago #16467
by naros812000
Replied by naros812000 on topic Cheverolet Optra 1.6L engine 2008
This model doesnt have IAC valve. it has Only tps driven by wire.
- Ben
- Thank you received: 215
8 years 9 months ago #16469
by Ben
Replied by Ben on topic Re:Cheverolet Optra 1.6L engine 2008
As Derek suggested clean the throttle body. The electronic throttle bodies are very sensitive to the oily carbon buildup around the throttle plate
- derekoliveira
8 years 9 months ago #16470
by derekoliveira
Replied by derekoliveira on topic Re:Cheverolet Optra 1.6L engine 2008
I am sorry but don t know about that system. If is drive by wire most probably you have exactly what Ben say...Opel 1.8 and 1.6 around 1998-2004 this happens a lot!
8 years 9 months ago - 8 years 9 months ago #16475
Replied by Chad on topic Re:Cheverolet Optra 1.6L engine 2008
+1 for cleaning throttle body
Look at the 3 minute mark.
Last edit: 8 years 9 months ago by Chad.
