92 Acura Integra LS Automatic 1.8l non vtech
  • ryan.humphrey
  • ryan.humphrey's Avatar Topic Author
8 years 9 months ago #16127 by ryan.humphrey
92 Acura Integra LS Automatic 1.8l non vtech was created by ryan.humphrey
So I have an 92 Acura Integra LS, Automatic transmission, 1.8l no vetch, having a no start issue. The fuel pump will not kick on, and the car will not fire , but if you jump in the main relay, and pour some gasoline In the intake it will fire. Only if you run a jumper wire in between though. Unsure of the cause it’s a head scratcher any help would be much appreciated
8 years 9 months ago #16130 by arbez
Turn the key to on & watch the check engine light. The light should come on for approx 2 seconds & then go out. Do you hear the main relay click when the light goes out?
Check I/O's at the main relay & let us know what is missing
Yellow/White - Battery +
Black/Yellow - Battery +
Blue/White - Starter Signal
Black - Ground
Yellow/Black - To Fuel Pump
Green/Black - Ground from ECU
Check all (except starter signal) with key on, in that first 2 seconds when the check engine light is on. Check the starter signal while cranking.
Let is know what you find
8 years 9 months ago #16137 by Tyler
Do this. ;-)
For our info, where exactly are you adding the jumper wire? From B+ to the fuel pump output of the main relay?
Time to create page: 0.259 seconds
