chevy impala intermediate no start
  • Albee9
  • Albee9's Avatar Topic Author
10 years 1 month ago - 10 years 1 month ago #1652 by Albee9
chevy impala intermediate no start was created by Albee9
Ok Mother-in-law brings her car over to Autozone because of CEL they got no codes.
So she comes to me and asks if I could get codes from a relay or the ignition switch I tell her no.
So she tells me her CEL is on they got no codes and sometimes it acts like it won't start.
I try to start the car a few times and I confirmed what she said So I tell her to let me put my scan tool (Autel ds708) on it to see what it tells me.
So I do and get no codes I go to start the car and it won't start and disconnects the scanner.
any ideas?? Thank you in advance
P.S I also started the car by turning the key to crank and immediately let the key go.
I forgot It's a 2008 Chevy Impala 3.5L
P.P.S I know about the recalls
Last edit: 10 years 1 month ago by Albee9.
  • cheryl hartkorn
  • cheryl hartkorn's Avatar
10 years 1 month ago #1654 by cheryl hartkorn
Replied by cheryl hartkorn on topic chevy impala intermediate no start
I would do an "auto scan" with the ds708. instead of just the ecm. I have the same scanner. let us know what you get.
10 years 1 month ago #1655 by Caritech
Replied by Caritech on topic chevy impala intermediate no start
The car won't start if you hold it in crank vs a quick "snap" of the key? It cranks every time? At point of no start, what's missing (spark, fuel etc.)?
  • Albee9
10 years 1 month ago - 10 years 1 month ago #1657 by Albee9
Replied by Albee9 on topic chevy impala intermediate no start
I did an auto scan and the only codes I got were for air bag and A/C .
When I went to start the car it would not start and shut down the scanner it should not do that I should be able to start the car with the scanner hooked up.
10 years 1 month ago #1658 by Caritech
So on a crank the scan tool shuts off completely? If so, the ECM could losing power or ground causing a no start.
The following user(s) said Thank You: Albee9
  • Albee9
10 years 1 month ago #1660 by Albee9
That's what I thought I'll check the ECM and see where that takes me
  • cheryl hartkorn
10 years 1 month ago #1679 by cheryl hartkorn
so when it doesn't "start" its a no crank? or A crank no start?? next time it happens id check for voltage on the s terminal of the starter with a test light. could just be a bad starter. if you have power put a starter in it.
  • Albee9
10 years 1 month ago #1695 by Albee9
I wanna thank everyone for their help But I'm no longer fixing this problem.
Again Thank you
